Hey... so I have a problem (you can skip the first 30 seconds or so):
http://www.youtube.com/watch?v=vjRRSktlVlk
and I'm wondering if there is any way to slow down the video to roughly fit with the audio. A kind of video stretch method would be nice... If any one else has had this problem before, how did you go about fixing it?
i hate bad cameras...
thanks for your time![]()
Most linear timeline editors like Sony Movie Studio are quite useful for stuff like that.
For a fairly rough, ghetto way of doing it, VirtualDub is able to alter the framerate to match the audio, if you're able to import the video into said program. Then you can resample the rate to a more standard one than whatever the arbitary output is.
Or, you can alter the audio to fit the video, which may be simpler. Something like Audacity should be able to do a good quality stretch, or again Virtualdub comes with built in filters for this stuff nowadays.-= She sez there's ants in the carpet, dirty little monsters! =-
Back after a long time away, mainly because I now need to start making up vidcapped DVDRs for work and I haven't a clue where to start any more!
Video won't fit on dvd
By chevyfever in forum Video ConversionReplies: 5Last Post: 6th Nov 2009, 08:50 -
Avi Video That will Fit a CD
By niteghost in forum Video ConversionReplies: 7Last Post: 26th Apr 2009, 10:21 -
Can I fit 5.3 GB video on a 4.7 GB DVD?
By better life in forum Authoring (DVD)Replies: 13Last Post: 16th Nov 2008, 21:42 -
video doesn't fit my TV screen
By hzgg2 in forum Authoring (DVD)Replies: 3Last Post: 21st Jun 2008, 07:56 -
audio-normal / video-slow
By Explorateur in forum Newbie / General discussionsReplies: 4Last Post: 9th May 2008, 12:18
