I have a srt file i want to change Font/Size and color... I have subtitle workshop but rarely use it..is their a way i can do it within that programme..i cant seem to find a way if their is... or maybe someone can suggest something else...Ps i want to keep the file as a srt when saved back out..Many thanks
You can't change any such settings in a srt file. You must adjust those settings in the player that uses the srt file.
Not with .srt, AFAIK. They are just text that the playback device interprets. You would have to make adjustments with the playback device. Other types of subs are adjustable.
I have been able to adjust srt font, size, color, etc using Subresync from the Vobsub package. Actually, I only used it once and found a style that I like and I now simply use the same style on all of the files that I hardsub.
Basically, I have a file called style.txt that looks like this:
Code:ScriptType: v4.00+ PlayResX: 1280 PlayResY: 720 [V4+ Styles] Format: Name, Fontname, Fontsize, PrimaryColour, SecondaryColour, OutlineColour, BackColour, Bold, Italic, Underline, StrikeOut, ScaleX, ScaleY, Spacing, Angle, BorderStyle, Outline, Shadow, Alignment, MarginL, MarginR, MarginV, Encoding Style: Default,Tahoma,48,&H00ffffff,&H0000ffff,&H00000000,&H80000000,0,0,0,0,100,100,0,0.00,0,1,0,2,20,20,20,1
update: I am not sure how you are trying to use these srt files. This method will work when hardsub'ing and should also work when playing back on PC. Not sure about other players though.Last edited by txporter; 22nd Apr 2010 at 15:11. Reason: update
I am not sure if you had it set up correctly or not. Did you have files that looked like this?
movietitle.mp4 (video file)
movietitle.srt (subtitle file)
movietitle.srt.style (style file - text in the [code] box above)
Vobsub is what is used to display the subtitles. You are probably already using it with MPC-HC.
Not sure I understand your last statement about soft subs vs hard subs. You got it to work with hardsubs but not soft?
Subtitle font color
By stem300 in forum SubtitleReplies: 3Last Post: 12th Dec 2011, 13:30 -
Changing font size/color for hardcoded subtitles
By JMantis in forum SubtitleReplies: 4Last Post: 6th Mar 2011, 19:34 -
Change Font Colour for .srt subtitle file!
By mufu in forum SubtitleReplies: 2Last Post: 5th Nov 2008, 14:45 -
Can I burn VCD or SVCD on DVD±R/W?
By Baldrick in forum Authoring (DVD)Replies: 111Last Post: 30th Aug 2008, 16:38 -
edit subtitle's font and color
By paseo in forum SubtitleReplies: 19Last Post: 4th Feb 2008, 05:32
