  1. Member jakewoodblues's Avatar
    Nov 2006
    Hi --
    I'm currently using DVDit 6 Pro & I'm not crazy about it. I don't like some of the menu & routing that is set in the system. I also have problems making dvd's with subtitles -- a problem, I'm told is universal.
    So...
    I'm looking for DVD authoring software that is:
    1) easy to learn
    2) has menus I can create
    3) allows the use of subtitles
    Dolby 5.1 would be good, but not a deal breaker if not available.
    Any thoughts or suggestions?
    I use 64 bit Windows 7.
    Thanks!
    "It's more like a big ball of wibbly-wobbly, timey-wimey... stuff"
    The 10th Doctor from "Blink"
    DVDit 6 sucks, I don't blame you. DVDit 5 was just as bad. The last good DVDit was 2.5 PE.
    I highly suggest Ulead DVD Workshop 2.
    - Buy it for huge discount ($100's off MSRP), currently $25.
    - Guide to use DVDWS2.
    - How to install DVD Workshop on Windows Vista or Windows 7
    DVDWS2 is simple to use, but still has pro features and power.
  3. Member jakewoodblues's Avatar
    Nov 2006
    Man, you're fast. I was just about to edit my post to mention that I had DVDWS 2 & did just what you suggested. But it didn't work.
    Any suggestions. Maybe you can tell me what I did wrong.
    Thanks!
