I have four wmv files totaling 3.2GB which are one movie that I would like to watch on a DVD player.
How should I go about doing this?
Should I merge those files into a single wmv and then convert it to avi or DVD, I think DVD would be better because you never know if avi will play on DVD players...which freeware software should I use to get this done, and what would be the most easiest way to do this?
"The greatest tragedy in mankind's entire history may be the hijacking of morality by religion." Arthur C. Clarke
Remember that WMV can be compressed more efficiently than mpeg-2, so you may not be able to fit the full 3.2 GB of WMV onto a single DVD and maintain the quality.
Filesize = bitrate x running time. The longer the running time, the smaller the bitrate and therefore the lower the quality.
What is the combined running time of your WMV files ?Read my blog here.
How To Produce High Quality WMV from AVI / DVD Files?
By devilcoelhodog in forum Video ConversionReplies: 3Last Post: 24th Jan 2010, 22:13 -
Is one of these capture methods better for quality than the other or equal?
By twolf13 in forum Capturing and VCRReplies: 3Last Post: 20th May 2008, 11:12 -
Low size, high quality WMV files
By devilfruit in forum Video ConversionReplies: 2Last Post: 29th Jan 2008, 18:08 -
Different size but equal quality?
By mai_hnf in forum Video ConversionReplies: 4Last Post: 5th Oct 2007, 10:59 -
Convert DVDs to WMV files while Maintaining DVD 5.1 Audio and Video Quality
By JBredensteiner in forum DVD RippingReplies: 3Last Post: 18th May 2007, 18:58
