if i clip up a section in videoredo, and then want to re-edit that clip into multiple other clips, will the reediting lose quality from the original edit? also which h264 container should i be saving in to have the maximum quality, i have h264 transport stream or m2ts or what?
also, if i am using uncompressed formats when editing in an editing program, when authoring as a bluray it will decrease the quality considerably? if my footage is 1080... im authoring in videostudio
cheers
	Working in reverse order
 1. Maybe. If you use a quality encoder with appropriate settings and a high bitrate then you most likely will not suffer any significant drop in quality, and to people who have not lived with the footage up close like you have, it will look fine. If you try to put it on a DVD at bluray resolution (i.e. AVCHD) then yes, you will notice a hit because the bitrate will be substantially lower than bluray needs or allows.
 2. Container makes no different to quality if you aren't re-encoding. The container is just that - a box to put the video in.
 3. VideoRedo only re-encodes the GOPs that you cut. Everything else remains untouched. In theory, if you keep making a lot of cuts in the same GOP you might get some degradation, but just making a second trim is unlikely to make a huge difference, and it will only affect a small number of frames.Read my blog here.
  Alternative to VideoRedo for Editing MPEG2 Files?By christopheramos in forum EditingReplies: 34Last Post: 20th Jan 2015, 15:09
  VideoReDo now does H264/AVC editingBy VegasBud in forum EditingReplies: 2Last Post: 18th Jan 2010, 05:15
  Any tools like VideoRedo for editing h.264 .tp files?By cwy in forum EditingReplies: 2Last Post: 11th Sep 2009, 11:40
  Editing unedited Wedding DVD + frame edits?By OldCanon in forum EditingReplies: 2Last Post: 8th Mar 2008, 13:41
  VideoRedo->DVRMS Issue, VideoRedo->MPEG2 Fine, Please HelpBy tbrnet in forum Video ConversionReplies: 0Last Post: 10th Jan 2008, 17:43
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
