I have Hi 8 tapes. I have the use of an older Sony camcorder (model TR 940) which has an S video outlet and RCA ports. I have found that I can buy an S Video/RCA cable w/ a USB end, and hope to find one w/ a firewire "800" end. However, someone told me that I had to convert the analog tape, and could not go directly from the Sony camcorder to the iMac without first going through a conversion of the analog tapes. Yet, I seem to read somewhere on VideoHelp.Co forum that you can go directly. I am confused.
If the only outputs you have from the camcorder are S-video and composite, you would need a video capture card. There are cards that are external and have a USB output interface. If the camcorder does have a FireWire output, then you would need a FireWire card on the computer.
And welcome to our forums.
Some Digital8 cameras could play back Hi8 and convert them to digital on the fly to output via firewire. Your camera is just a Hi8 camera and only has analogue output. You could buy a cheap and nasty USB converter that will take your camera inputs, or look at something like an ADVC device that converts analogue to DV (similarly to what a Digital8 camera would do) and capture via firewire.
Factors to include in your decision include how many tapes you have, how much you want to spend, and what, if any, editing you want to do to the video.Read my blog here.
Capture Analog 8mm Video 8 Tapes to DV - What equip will produce best Qual
By koop in forum Capturing and VCRReplies: 7Last Post: 5th Apr 2012, 00:36 -
Best way to convert analog 8mm tapes to digital
By charliedog in forum Newbie / General discussionsReplies: 7Last Post: 29th Nov 2011, 03:15 -
Converting Analog Hi8 tapes to Digital to PC
By Dicka24 in forum Capturing and VCRReplies: 9Last Post: 4th Jan 2011, 13:07 -
Analog tapes to PC
By stellabelch in forum Capturing and VCRReplies: 8Last Post: 23rd Oct 2009, 12:57 -
Analog to DV Tape vs. Analog directly to computer
By jlorelle in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 16Last Post: 7th Sep 2008, 10:45
