If i am going to convert a dvd movie into x264 should i leave the resolution at 720X480 or should i let the program determine the resolution. What would be the advantage of the program picking 640X480? Will it still be the same size on my TV? In other words if the dvd takes up the full screen on my tv, and the resolutuin is changed by my encoding program, will it still take up the full screen or add bars or sommething? Thanks
Results 1 to 11 of 11
640 x 480 is the square pixel (PAR 1:1) resize of 720 x 480. Both will play back correctly. Not all players handle non-square PARs correctly outside DVD structures, so to play it safe 1:1 PAR resizing can be applied. It also, in this case, reduces the overall resolution, which may give you better bang for your encoding buck.
Read my blog here.
I usually leave the video at its original resolution and set the PAR/DAR flags. All my players now support that.
For highest quality, you should use Strict Anamorphic to retain the original resolution (which also sets the correct flags to make the encode display at the right aspect ratio). Remember to use Auto-crop too.
Only if the bitrate is extremely low, like 500kbps. For normal and higher bitrates, original resolution (no resizing) is always better.Originally Posted by gunsl1nger -
Question: which is it of the below shapes?
a/ 4:3 (ie "narrowscreen")
b/ letterboxed (black bars as a part of the actual video, NOT added e.g. by the television/DVD player when playing a widescreen film on a narrow TV --- so you have to "zoom" on a widescreen to make it look correct)
c/ fullscreen 16:9 (widescreen) --- if you're unsure, then without adjustment, everything will look squashed at 720x480
In which cases, if you want the FULL quality with no vertical resizing/deinterlacing/etc:
a/ 720x480 if you can rely on the player auto-reshaping it. 640x480 for square pixels.
b/ 720x352 (or 360, 368), or again 640 wide for squares
(if it's letterboxed from some aspect other than 16:9 this may be different - i.e. 408 high for wierdass 14:9, 400 for 16:10, and various sizes LESS than 350 for cinemascope and the like)
c/ 720x480, or 848 (854)x480.
If it's a film or you don't mind an adaptive deinterlacing step with slight loss of vertical clarity, c/ could also be something like 720x400, 640x360 etc.
Mind that this only works if the PLAYER software supports the flags, which some don't - including the lowest common denominator, i.e. Win Media. You'll have to use something like VLC. In which case, why not just bite the bullet and get a hard disk big enough to store the original DVD rips?strict anamorphic, correct flags, etc
720x384 sounds like a wierd setting, by the way (80% of original height, for a 10:6 ratio). I wonder what the reason is?
Damn, man. 500k is the point where I'm looking to step down FURTHER from, e.g, 640x360. You do start getting additional artefacts at that point, and that's with quiet, low-motion stuff (for perspective, you'd get over 2.5 hours on a CD with 128kbit audio).only for very low bitrate, e.g. 500k
For full-D1-rez NTSC, I'd peg the divider closer to 750 or more - again, for quiet stuff (typical movie is still a single disc at 960+128). More action will increase the need, and reducing pixel area is a good way of countering it, as you get exponential gains. (0.8 reduction on each axis = 0.64 area).
It will depend, really, on how much space you can throw at each hour of video, what storage media you're using, and how long the shortest acceptable unbroken segment is. And depending on material and encoder, YMMV from what I get from my own kilobits anyway.
Downloaded movies I've seen don't tend to be over 640x352 for an hour and a half inside 700mb, mind, and even so their quality could be better. 576x324 is a near imperceptably smaller alternative allows about a 15% saving. And of course, this is for full-frame, if there's any letterboxing you can trim it harder (not saving a great deal because nothing happens in the borders, but it helps you do the math).
Resizing loses you pixel definition, it's true, but if you get to the point where there's obvious MPG artefacting, the image has been hurt in far more painful ways than what is effectively a slight softening.Last edited by EddyH; 22nd Apr 2010 at 10:00.
-= She sez there's ants in the carpet, dirty little monsters! =-
Back after a long time away, mainly because I now need to start making up vidcapped DVDRs for work and I haven't a clue where to start any more! -
So it sounds like the best option is to re encode the video in the same 720X480 Resolution without resizing?
Yes, using Strict Anamorphic.
How does that follow?? In the first place, WMP can't/couldn't even play x264-in-MKV files on its own, so obviously another player is being used, or a codec and splitter have been installed, etc. I myself haven't used WMP in maybe 8 years, and lots of people I know use other players and codec packs. Why should storing the original DVD ISOs be necessary?
Well, I'm not advocating 500kbps at all - just giving an example of when it makes sense to downscale. At normal bitrates of 1200-1800, there's simply no point in resizing unless your player is a piece of shit that can't read anamorphic flags. (Not being able to display MKV/MP4 video anamorphically is pretty pathetic, seriously.)Damn, man. 500k is the point where I'm looking to step down FURTHER from, e.g, 640x360. You do start getting additional artefacts at that point, and that's with quiet, low-motion stuff (for perspective, you'd get over 2.5 hours on a CD with 128kbit audio).only for very low bitrate, e.g. 500k
Sure, 750 is a good dividing line for choosing when to downscale.For full-D1-rez NTSC, I'd peg the divider closer to 750 or more - again, for quiet stuff (typical movie is still a single disc at 960+128). More action will increase the need, and reducing pixel area is a good way of countering it, as you get exponential gains. (0.8 reduction on each axis = 0.64 area). -
Forget bitrates and use constant quality (or quantizer) encoding. You'll always get the quality you specify.
Encode video with different luminance resolution and video resolution
By kylix999 in forum Video ConversionReplies: 14Last Post: 6th Jun 2012, 07:57 -
Resolution Question
By killerteengohan in forum DVD RippingReplies: 14Last Post: 9th Aug 2011, 22:00 -
Auto adjusting screen resolution to video resolution
By Computer Nerd Kev in forum Software PlayingReplies: 11Last Post: 11th Jul 2011, 06:36 -
viewing a QVGA/VGA resolution video with NTSC DV resolution (with a TV)
By Lightbreaker in forum EditingReplies: 1Last Post: 6th Jan 2009, 01:57 -
DLP Resolution Question ?????
By ofield1 in forum Newbie / General discussionsReplies: 2Last Post: 25th Feb 2008, 19:44
