I recently bought the Canon HFS 10 camcorder and would like some help with the following:
1. Need to convert the contents to a regular DVD format with menus
2. Need to convert the contents to Blu-Ray format with Menus.
I am not much into editing but rather just convert the files to an optical disc so I can remove them from the SD card and have permanent storage. What software would give me a good end to end solution and is my computer config good enough for the task![]()
I would give tmpgenc authoring works a try. Both dvd and blu-ray authoring.
You could try this programe it's free too.
https://www.videohelp.com/tools/multiAVCHD
multiAVCHD allows you to turn a bunch of MKV, M2TS, TS, VOB, AVI files and a bunch of DVD, Blu-ray/AVCHD/BDMV folders into disc with a simple menu structure that should play on Blu-ray players. Put up to 252 different files, MPEG2, Quicktime MOV, MKV/AVC, M2TS/MTS, TS and AVCHD/BluRay folders in one place and navigate all these via nice 1080p top menu. One click DVD to Blu-ray/AVCHD(no reencoding). -
Thank you both Baldrick and NWO. I really appreciate your input. I will try them and post back with any questions/results
Flix
What Is The Bost Most Lossless Format To Convert .mts Files To?
By JohnnyGalaga in forum Newbie / General discussionsReplies: 24Last Post: 10th Feb 2016, 20:27 -
Joining mts files to one video with chapters (Blu-ray)
By Gibbus in forum Authoring (Blu-ray)Replies: 1Last Post: 2nd Oct 2011, 03:25 -
Sample Blu ray, m2ts, mts files
By pepegot1 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 8th Jan 2011, 15:15 -
Convert .MKV to .MTS (AVCHD) for use in BD 35 Blu Ray player
By NirvClub in forum Newbie / General discussionsReplies: 7Last Post: 7th Feb 2009, 15:51 -
how to burn and play the MTS files on standalone blu ray player using BD R
By ticos2000 in forum Authoring (DVD)Replies: 12Last Post: 28th Jan 2008, 19:06
