  1. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    If the DVD you are working with has subtitles, then the subtitles will be retained in the resultant mpeg.
    So, if your player supports subtitle streams, you can turn them on and off. For example in VLC:
  2. Member Joey9's Avatar
    May 2010
    Brooklyn
    That's a great improvement ChrissyBoy. I remember the old versions wouldn't transfer the subtitles, a real pain, had to use DVDSubEdit to extract the subs. Thanks, and keep up the good work on VOB2MPG.
  3. VOB2MPG free works great, but it looks like the subtitles aren't transferring. Is this only for the Pro version?
    Thx.
