I just turned my PC off to install a HDD. I turned the PS off and hooked up the drive. I turned the PS back on and the CPU fan, the power fan and the light on the MB comes on and goes off continuously without powering up the PC.
Reverse what you did and see it it boots.
The HDD takes mostly 12VDC, same as the fans and mobo.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
I reached up an unplugged the power to the DVD Drive that I am temporarily replacing with the HDD and it fired right up. Still don't know why it caused it to not boot and why unplugging it would fix the problem.
I have never seen anything like this before. My brother had an Asus board that he put in a cheap case and it would do something like this but it only did it once and shut down. We followed Asus advice of trying to start outside of the case and it fired up so we knew the case was bad. -
The computer is home built.
The board and CPU are a couple of years old. Gigabyte P35-DS3P with Q6600. The PS is a couple of months old. Corsair TX750W. I bought the case last week. Coolermaster CM-690. -
I had this same problem on a homebuilt: I'm embarrassed to say I was using a HD cable that I was somehow able to install reversed on the drive; i.e., Pin 1 to #40 connection, Pin 40 to #1 connection.
When I made the correction connection, all was well, and I was VERY pleasantly surprised that I had done no damage.
Lacie Cinema: Can't power device on using remote but will power on with USB
By truequant in forum Media Center PC / MediaCentersReplies: 1Last Post: 14th Nov 2011, 03:03 -
Building a Low Power Desktop...with Laptop like power?
By Moontrash in forum ComputerReplies: 31Last Post: 18th May 2010, 22:15 -
Constant resolution in GK
By eliqush in forum EditingReplies: 0Last Post: 5th Aug 2009, 10:28 -
Downloading Motherboard Upgrades to my Motherboard
By orfajackson in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2009, 15:54 -
I need a constant bitrate
By alexv305 in forum Newbie / General discussionsReplies: 6Last Post: 6th May 2008, 06:38
