I am looking for the best product to capture video and then use that video to create VCD's of television shows. I would rather not have to deal with my VCR in this as it's getting older, and I don't have cable at the moment. I've been using antenna and it works fine to see my favorite shows. I get all the major basic networks this way--WB, UPN, NBC, ABC, Fox, etc. Is there a card I can use with this setup that will allow me to bypass the VCR to record a one hour television show? And also maybe video from downloads? Also, it would be nice to have some upgradability so that when I go to cable within the next few months, it will be a smooth transition. I'm looking to meet my needs as inexpensively as possible, but still have a good setup. Any advice on the best products to research?
Thanks. :D
Chris Smithe
basically any TV capture card can do what you want, even if your VCR doesn't have line outs.
antenna -> vcr -> coax [splitter] to PC-TV card & TV
or
antenna -> vcr -> coax to TV, vcr line outs to PC-TV card
for playback on tv you need video/audio outs to TV or VCR LINE IN - the TV out is usually on your video card and soundcard provides the audio out.
as for which kind of card to buy? well, can only say don't buy ATI
Problems with capturing using ION VCR 2 PC
By mostly_useless in forum Capturing and VCRReplies: 0Last Post: 21st Dec 2011, 19:16 -
Looking for Good VCR for Capturing
By zerowalker in forum Capturing and VCRReplies: 0Last Post: 28th Nov 2011, 18:56 -
Need Help Urgently Capturing from SVHS VCR
By Hairykiore in forum Video Streaming DownloadingReplies: 9Last Post: 4th Aug 2011, 20:26 -
VCR capturing question?
By s3r19lk1ll3r in forum Capturing and VCRReplies: 1Last Post: 17th Oct 2010, 22:26 -
Having problems capturing from VCR
By Confused Chimp in forum Newbie / General discussionsReplies: 5Last Post: 29th May 2007, 03:41
