Delete the post.
Results 1 to 30 of 38
dvdrebuilder with hcencoder is the best.
ANd I'm moving you to our dvd ripping and converting/shrinking section. -
Do you really want to keep ALL of the DVD...including the extras and nag screens and warnings and previews of movies you are not interested in?.....then do a complete backup.
Personally I'd rip the disc to my hard drive then load it into DVDShrink and select ONLY the movie. You'd be surprised how many bloated dual layer DVD releases contain the main feature(movie) that can easily have fit on a single layer DVD.....the rest is just garbage to most people.
My two cents anyway.... -
DVD Decrypter or DVD Shrink are fine, if they work, and I find that they work 90%+ of the time, particularly for pre-2005 DVDs. Personally I use RipIt4Me for first tries, which invokes the prior two titles automatically as well as a built-in FixVTS. If that doesn't work I resort to DVDFab, which almost invariably works, unless possibly it's a very recent release (within the last few weeks/months). I'm not familiar with DVDCloner. If you set any of these rippers to 100%(R9/DVD9) you shouldn't lose any quality with the transfer to HD. The only qualification is that I recommend running FixVTS on the resulting HD VIDEO-TS folder files to correct possible pointer errors which happen occasionally, especially with DVDFab. Then you should be all set to shrink with software of your choice.
Nobody here gets paid to provide replies. Consequently none of us has any obligation to provide quick help. For example, many helpful posters don't participate on weekends here because they have better things to do.
And what on earth is so important about shrinking a DVD that it has to be done now as opposed to 4 hours from now or tomorrow or the next day? I've often found that the more desperate a poster is for immediate help, the less of a real emergency it usually is. -
Those who don't want to help should keep their mouth shut, not insult the poster. That makes this an unfriendly forum.
I don't think there's anything wrong with hech54's response to the original poster's untactful tone/phrasing. Regulars here are helpful, but there's no reason why they should ignore comments that sound insulting or entitled instead of responding to them. We're not a business dealing with customers here; no need to coddle people asking questions.
(In case you didn't realize it, charmed94's phrasing was rude.) -
" Who needs Google, my wife knows everything"
This is my basic process:
DVDFAB (main movie only) -> HDD (video_ts folder) -> DVDShrink (if needed) OR DVD Rebuilder (if needed) -> HDD (I save the resized video_ts folder in place of the original) -> imgburn (burning software strongly recommended by this forum for good reason!) -
You do not need to have five copies of the same DVD on your drive ("5 DVDs of the same content"). That's simply redundant. You only need to copy it once, then burn DVDs from that copy.
It's time to get a new hard drive and to start using dual-layer discs. Both are cheap enough now that there is no excuse to be left with no space on your HD, or the need to shrink your discs.
You really shouldn't have needed to read beyond the second response (Baldrick). The DVD-Rebuilder site has a FAQ and tells you exactly how to set it up. As a matter of fact, there was probably no need for this thread at all. You even searched for a guide elsewhere, so you've basically wasted everyone's time.
Even though hech54, jman98 and other posts seem like they don't belong, they are very helpful if you use the lesson contained in them. They are showing that there is a method to getting your questions answered (don't be greedy or demanding), and to include as much info as possible in order to solve your problem. As it stands, your problem is very petty (not that there are any real emergencies cropping up on these boards). -
Imgburn has been proven to be the most reliable software for burning dvd-/+r(w) and dvd +r dl media.
Also remember to stick with good quality media like TY or verbatim dvd -/+r media or verbatim dvd +r dl media.
I always burn first to a verbatim dvd-rw to ensure a good burn, then i copy to a verbatim dvd-r.
Good luck with your project. -
I guess that's one of the problems of an international site like this is that sometimes things just don't translate quite like what they were meant to be.
Charmed94 the only thing that I can suggest to you is to change your location to show your actual location (country). That way the native english speakers here would understand that english wasn't your primary language. Then people might let things like what you wrote slide.
As far as your english goes it's actually pretty good. A lot better than I do at speaking foreign languages. The only one I can halfway get by in is Spanish and I'm not very good at that.Donadagohvi (Cherokee for "Until we meet again") -
It has often been said that HCEnc is a superior encoder for low bitrates. My own experience leads me to believe that is correct, it's probably a better choice than CCE for low bitrates. However, to imply that CCE is inferior overall is stretching the point. It sounds to me that the CCE setting for flat-part priority (quantization) was radically wrong for the available bitrate. And of course CCE is a good deal faster, with comparable output to HCEnc at reasonable bitrates.
Nevertheless, HCEnc is a damn good encoder, and it's free.
I hope I'm not starting something here, but this subject has been discussed a lot over the years.
Pull! Bang! Darn!
DVD9 split to two DVD5's while retaining menus and video quality
By ashes2flames in forum DVD RippingReplies: 6Last Post: 28th Feb 2011, 09:10 -
burn dvd9 to dvd5 and still keep 80 to 100% video quality
By vance43211 in forum User guidesReplies: 35Last Post: 6th Dec 2010, 09:40 -
DVD9 to DVD5
By roflwaffle in forum DVD RippingReplies: 5Last Post: 3rd Nov 2010, 17:52 -
Splitting a DVD9 into 2 DVD5's with 100% quality?
By alegator in forum DVD RippingReplies: 10Last Post: 22nd May 2008, 17:10 -
How to shrink DVD9 to DVD5 with no Quality loss?
By CERO in forum Newbie / General discussionsReplies: 7Last Post: 4th May 2008, 07:18
