I got a Pioneer A03 DVD recorder this week. Found that the bundled software PrimoDVD stinks for making data DVDs, so I got Nero 5.5.78. It was nice to see the framilar interface. I built a data DVD with it. But it doesn't seem to support multisession burning.
Does anyone know if you can do multisession burning on a DVD-R?
Does the Pioneer A03 support multisession DVD-R?
Does Nero support multisession DVD-R?
It seems tedious to have to save up enough data before performing a single burn session to a DVD-R data disk. I've been spoilled to CD-R multisession for data backups.
Any help would be appreciated!
AFAIK, DVD-R does not currently support multi-session, though I would be happy to be corrected on this
The only app I know that supports multi-session DVD-R writing is Roxio DirectCD. Please note that any DVD-ROM drive that you are planning on reading this with will have to support Multi-session/Border reading. Pioneer's DVD ROMs the 116 and 117 will read multi-session DVD-R.
Of course I do not like to have DirectCd loaded onto my system because it is a resource hog and it can cause compatibility problems with other
S/W.
RG -
After digging through Pioneers support pages (hours). I found that the player does support MultiBorder, but they didn't know of any software out there at the time which would write this.
I have Roxio EZ Creator Plat. but read there are problems having Nero and DirectCD loaded at the same time.
Perhaps I'll try DirectCD.
why can't I produce an ISO from a multisession track DVD ?
By Bansaw in forum Newbie / General discussionsReplies: 5Last Post: 20th Dec 2010, 11:43 -
Multisession DVD Burner and Burning Files into Specific Folders
By Disco Makberto in forum ComputerReplies: 9Last Post: 23rd Feb 2010, 02:48 -
Will Nero 7.0 do a Multisession DVD
By scustalow in forum Software PlayingReplies: 6Last Post: 1st Oct 2008, 13:16 -
Can only read the first session in a MultiSession recorded DVD?
By demf in forum DVD & Blu-ray RecordersReplies: 1Last Post: 19th Sep 2007, 12:16 -
multisession CD R???
By xiaofan in forum MediaReplies: 10Last Post: 11th Jun 2007, 05:12
