I have some tv shows that the resolution is smaller and it fills up the screen. I have some that I converted to 720p and 1080p and it doesn't fill the screen. You get black bars on the side. Is that because the original person that uploaded the videos set it up that way? Is their a way to get those videos to fill the screen?
http://www.kiva.org/about -
The resolution only tells part of the story. For example, a 4:3 movie encoded at 1920 x 1080 will have black bars up the sides to preserve the original aspect ratio.
That said, if 657 x 548 is filling the screen, it is either being zoomed, or displaying distorted, as it is not a 16:9 resolution (and it is really badly encoded - odd number resolutions are usually not allowed).Read my blog here.
DVD, DV, ATSC, DVB etc. files have non-square pixels (e.g. 704x480 or 720x480). These need proper scaling.
Many HD camcorder files have non-square pixels even though they are 16x9 (e.g. 960x720, 1440x1080).
Most broadcast and Blu-Ray HD files have square pixels (e.g. 1280x720 or 1920x1080).
So yes, more source detail is required.Recommends: Kiva.org - Loans that change lives.
This video is 16:9 1080p converted using xilisoft video converter ultimate
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 1.17 GiB
Duration : 52mn 59s
Overall bit rate : 3 164 Kbps
Encoded date : UTC 2009-12-22 04:21:52
Tagged date : UTC 2009-12-22 04:21:52
Video
Format : AVC
Format profile : Main@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 1 frame
Codec ID : avc1
Duration : 52mn 59s
Bit rate mode : Variable
Bit rate : 2 993 Kbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.048
Stream size : 1.11 GiB (95%)
Audio
Format : AAC
Format version : Version 4
Format profile : LC
Format settings, SBR : No
Codec ID : 40
Duration : 52mn 59s
Bit rate : 165 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Stream size : 62.7 MiB (5%)
I converted the same video to 720x480 to save HDD space and now the ratio changed and it doesnt fill the HDTV. screen. Is it because 16:9 is only for 720p and 1080p?
Format : MPEG-4
Codec ID : isom
File size : 557 MiB
Duration : 52mn 59s
Overall bit rate : 1 470 Kbps
Encoded date : UTC 2010-04-20 13:21:51
Tagged date : UTC 2010-04-20 13:21:51
Video
Format : AVC
Format profile : Main@L3.1
Codec ID : avc1
Duration : 52mn 59s
Bit rate : 1 337 Kbps
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 3:2
Standard : NTSC
Resolution : 8 bits
Colorimetry : 4:2:0
Bits/(Pixel*Frame) : 0.129
Stream size : 507 MiB (91%)
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 52mn 58s
Bit rate : 128 Kbps
Sampling rate : 44.1 KHz
Stream size : 48.5 MiB (9%)
Its weird because I also have an avi. and the resolution is 640x352 and the ratio is 16:9 and fills the screen. How do I get my videos to 16:9?
Format : AVI
File size : 796 MiB
Duration : 1h 49mn
Overall bit rate : 1 020 Kbps
Writing application : VirtualDubMod 1.5.10.1 (build 2366/release)
Writing library : VirtualDubMod build 2366/release
Video
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Muxing mode : Packed bitstream
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 1h 49mn
Bit rate : 883 Kbps
Width : 640 pixels
Height : 352 pixels
Frame rate : 23.976 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Bits/(Pixel*Frame) : 0.163
Stream size : 689 MiB (87%)
Writing library : XviD 1.1.0 (UTC 2005-11-22)
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Mode : Joint stereo
Format_Settings_ModeExtension : MS Stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 1h 49mn
Bit rate mode : Constant
Bit rate : 128 Kbps
Stream size : 99.9 MiB (13%)
Alignment : Aligned on interleaves
Interleave, duration : 42 ms (1.00 video frame)
Interleave, preload duration : 504 ms -
OK, I'll assume your AVC player only plays in square pixel.
1920x1080 is 16x9 aspect when viewed as square pixel
720x480 is 3x2 (13.5x9) aspect when viewed as square pixel. If it was flagged as 16x9, many players would horizontally stretch it for 16x9 display but yours is flagged 3x2 square pixel.
640x352 is 16.36x9 when viewed square pixel but is flagged 16x9 so many players would horizontally scale it to 16x9.
The 16:9 square pixel conversion for 480 lines is 853.3 but 853 is not divisible by 16. The closest option is 848x480 which would slightly squeeze the picture horizontally and show about 6 pixels pillarbox either side when enlarged to 1920x1080.
Instead of 848x480, many people use 720x400 for xvid which will play on many DVD players. 720x400 scaled sqaure pixel to 1920 would show slight letterbox.Recommends: Kiva.org - Loans that change lives.
AVI once converted has sync issues. Please Help!
By Marts1988 in forum Newbie / General discussionsReplies: 7Last Post: 5th Jan 2011, 01:45 -
Handbrake converted videos now 1/3 speed
By zelman in forum Video ConversionReplies: 5Last Post: 4th Mar 2010, 04:48 -
Videos converted skip and are cut off
By gdreger in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 28th Dec 2009, 15:12 -
How to best display music videos on a wall
By sybariten in forum Software PlayingReplies: 1Last Post: 26th Feb 2008, 13:50 -
Need help fixing up already converted DVDs of old videos
By t_burrito in forum RestorationReplies: 1Last Post: 10th Jun 2007, 00:32
