Hello specialists - I have a big big problem - my recorder is destroyed by water - ni chance to repair. But, I have some nonfinal DVDs. Is there a possibility to "final" the DVDs - that I can play on a normal DVD player - or on PC?
Thanks - a lot - sorry for my bad English............
You can finalize them any another Panasonic DVDR. You can also finalize them with PC programs but it's much easier to use another Panny. Check a few of the recent threads, one recent one was talking about PC programs to use, I've never done it that way.
Thanks a lot jjeff - so iI looked for a another DV.
I can get a DMR E50 - but the online manual says "you can only finalize DVD, which made on THIS unit - Is this true? I hope - NO. I cant believe this.
Please help me again
Thanks -
The E-50 is a '03 Panasonic, if your currently have a EH-50 that's a '05.
The thumbnail view option(where a little thumbnail accompanies each title) was added in '04, so I'm not sure how DVDs recorded on a thumbnail recorder will finalize on a non thumbnail recorder.
I'd also be a little leary of a '03 recorder and how much more life it has in it's burner.
Personally I'd try and find a '04 or newer Panasonic to have the thumbnail feature.
What page on the online manual are you seeing your quote? I'm not quite sure what it's trying to say. -
Thanx again - i will look for a newer Panasonic.
I found the note on page 40 at the English manual from 2004 -
Page 40 on the english manual I read only talks about home theaters? Even a basic model like the '06 ES-15(which many times can be found very cheap around here) would work good to finalize your discs.
http://service.us.panasonic.com/OPERMANPDF/DMRE50.PDF
VCR comparison Panasonic NV-FS200(AG 1980) VS Panasonic NV-HS1000
By JoseD in forum RestorationReplies: 32Last Post: 18th Apr 2016, 09:30 -
best vhs playback? panasonic nv-fs200 hq / panasonic dmr-e75v
By overheat in forum Newbie / General discussionsReplies: 6Last Post: 28th May 2009, 21:57 -
JVC DR-MH50S Loading Problem
By munish1000 in forum DVD & Blu-ray PlayersReplies: 9Last Post: 5th Feb 2009, 08:36 -
Panasonic DMR-EZ28 Previously Recorded Panasonic DVDs
By Surfmaster in forum DVD & Blu-ray RecordersReplies: 6Last Post: 20th Oct 2008, 21:45 -
black bars on sides of screen, Panasonic s97 to Panasonic e55
By southland66 in forum DVD & Blu-ray RecordersReplies: 14Last Post: 10th Sep 2008, 18:15
