I need to create a DVD that can show dozens of screens of information for my work colleagues.
I don't want a slideshow, as the person viewing needs some basic navigation- in other words, the screens will actually be menus with buttons enabling jumps to other screens.
The screens will contain mainly text and each jpg menu file will be automatically produced by adding the text from a database.
I've created some small sample XML project files for DVDStyler, but navigation is limited
Can anyone suggest a suitable Windows application.
I'm willing to give Linux a try if the right solution can be found!
Thanks in anticipation
	I've done this in DVDWS2
 - Guide @ http://www.digitalfaq.com/forum/showthread.php/author-ulead-dvd-1506.html
 - Buy @ http://www.bhphotovideo.com/c/product/311318-REG/Corel_Ulead_A25420111_DVD_Workshop_2....3167/KBID/4166 (only $25)
 Looks great. Want my help? Ask here! (not via PM!) Want my help? Ask here! (not via PM!)
	Thanks lordsmurf
 I've had a quick look at Ulead DVDWS2 details, but I can't find any indication that it will do what I want, unless of course I've missed it!
 You're probably familiar with DVDStyler and know that you can create an XML project file, containing all the menus etc. that you want to include on your DVD.
 DVDStyler reads this XML project file and then creates another XML file that DVDAuthor uses to create the DVD.
 I'm looking for something similar that offers better navigation features. There could be dozens (maybe hundreds) of menus involved- all acting as information screens to the person viewing.
 Thanks for your help.
  Whats a simple software DVD player that just works !By Bansaw in forum Newbie / General discussionsReplies: 4Last Post: 6th May 2011, 16:20
  whats authoring?By templedog in forum Newbie / General discussionsReplies: 3Last Post: 17th Nov 2008, 01:28
  Whats a good cd/dvd burnig software to be used mainly if not only fot data?By Denvers Dawgs in forum ComputerReplies: 11Last Post: 12th Jun 2008, 03:42
  Whats the Best Method/Software to encode file into DVD...?By snadge in forum Newbie / General discussionsReplies: 5Last Post: 8th Jan 2008, 22:38
  Best DVD Authoring SoftwareBy mai_hnf in forum Authoring (DVD)Replies: 3Last Post: 30th Sep 2007, 12:25
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
