I just purchased a Canon HF200 camcorder. I have had no problem getting the files onto my computer. But, from there I have had so many problems. I've tried editing them in Sony Vegas Studio Platinum trial version and Corel Video Studio Pro X3 trial version. I've also used Proshow Producer, a slideshow program that I love for my photography hobby. Each program freezes up or crashes when I am working with the files. Vegas has problems when I try to render, and Corel has had problems at a lot of different points, previewing and rendering. I've even had my computer crash a couple of times when just viewing the original files in Windows Media Player.
I'm assuming that this means that I have to convert the files into another form before editing. I've tried a few different trial and free video converters, but I really don't know what I'm doing and the quality of the conversions hasn't been nearly as good as the original files. I'm not sure what format to convert to and what settings to use.
Right now I will be burning the edited shows to DVD, although at some point I would like to get a BluRay burner. So shouldn't I be converting the files to the best possible quality so I can reburn my shows to BluRay at some later time?
So, what I am asking, is where would you go next if you were me. I've spent every spare minute for a week working on this and the more I do, the more confused I become.
My computer is a one year old i7 PC with 920@2.67 ghz, with 9gb ram, and an ATI Radeon HD 4800 series video card. I am downloading a trial copy of Adobe Premier Essentials right now to try.
Thanks for any help you can give me. I will be most grateful if someone could help me get started on the right path.![]()
Results 1 to 10 of 10
Thank you. Here is the information. Hope this is what you wanted. It produces AVCHD .mts files.
General
Complete name : C:\Users\Terri\Videos\Camcorder Videos\2010\April\2010-04-15\00002.MTS
Format : BDAV
Format/Info : Blu-ray Video
File size : 34.4 MiB
Duration : 11s 970ms
Overall bit rate : 24.1 Mbps
Maximum Overall bit rate : 24.0 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile : High@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Duration : 11s 878ms
Bit rate mode : Variable
Bit rate : 22.8 Mbps
Maximum bit rate : 22.7 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.368
Stream size : 32.3 MiB (94%)
Audio
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Format_Settings_ModeExtension : CM (complete main)
Duration : 12s 0ms
Bit rate mode : Constant
Bit rate : 256 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Video delay : -67ms
Stream size : 375 KiB (1%) -
I don't know if this helps, but I use Vegas Pro v.9 and it works great with .mts files from my HF200.
You can see the results on my Youtube page if you want.
http://www.youtube.com/user/chicagobirder
I would think any recent version of Vegas would work with .mts files. -
Audio is working now...... I had to install the AC3 filter. Now I will try converting a few files to see if my software will work without freezing up when I use them.
Canon HF200 help
By descotes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 18th Oct 2010, 15:28 -
Canon HF200 Useless So Far
By HF200Remorse in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 31st May 2010, 20:55 -
2 Mics for the Canon HF200... How?
By juststarted in forum AudioReplies: 3Last Post: 25th Nov 2009, 16:23 -
viewing hf200 on tv
By jim_joh in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 13th Oct 2009, 20:20 -
Canon HF11 or HF200?
By David97 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd May 2009, 11:09
