Yep, problem just doesn´t stop on me with this holy GUI, first it gives sync problem, MeGUI doesn´t, then I got the trick for less sync problem..AT END...with the script DirectShowSource("%source_file%", audio=false, convertfps=true) "It isn´t perfect, but it indeed work with VFR input converting it to _CRF and giving less possibilities of A/V sync problem" fit to say it functioned pretty well...but now it gives error just at the time of demuxing any kind of source I drop at it.
And bad stuff is..it was just fine right just about before....
This is the error I´m always getting each time I choose Directshowsource as my source filter for VFR/VBR input(If you know by know that these are our main culprit of our A/V sync problem friend)
And then another error after I hit Ok.
This precise source is name of sync problem with minicoder and StaxRip as well, but I sure know if I achieve directshow to function properly, staxrip won´t give such annoying problem.
Can you tell me if this problem happen in your StaxRip as well?
Do you think it doesn´t support AVC/.h264 codec?, if is that so, I as well used a AVC/x264 input and the same happen...
Any advice guy and I would trully appreciate, very desperate to continue my work now...Thanks you very much in advance.
				Results 1 to 1 of 1
  AVISynth Error DirectShowSource: Timeout waiting for graph to start - .m2tsBy onesikgypo in forum Video ConversionReplies: 2Last Post: 22nd Jun 2010, 22:30
  RipBot error - DirectShowSource: couldn't open fileBy sweetalmond in forum Blu-ray RippingReplies: 2Last Post: 20th May 2010, 23:42
  RipBot error -- DirectShowSource : Timeout waiting for graph to startBy crankharder in forum Blu-ray RippingReplies: 10Last Post: 20th May 2010, 10:19
  DirectShowSource: Couldn't open MKV file ERROR?By th3obr0 in forum Video ConversionReplies: 1Last Post: 9th Jun 2009, 06:53
  DirectShowSource error in Ripbot264By reiter der hoelle in forum Blu-ray RippingReplies: 1Last Post: 15th Dec 2008, 03:22
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
