Greetings,
Ive seen a couple movies of a game I play that some people have made. Most of them, or all, have a Geforce card with a tv.out that they put to a vcr to record. then use premiere to edit the movie.
I have a regular Geforce2 w/ no tv out. :(
I was hoping for something that could the read the video out, software wise, and make a movie. But I now think that to be science fiction.
Are there any cards that record directly to the harddrive from the video card? So I can skip the whole VCR part? Just get a bunch of a footage from the game and edit from the HD.
I want a card that gives decent quality and is cheap and preferably doesnt require a vcr. Of course those cards may be too expensive or nonexistant :D
I was looking at the cheap pinnacle and ati tv cards. But I think the tv part may mean I need a vcr todo what I want.
I got 100gb of diskspace and plenty of horsepower and ram. Pretty good skills with ccesp, vdub, tmpge; so as long as its in a decent format I can work with it.
Oh, and looking at the list, most cards are winxp? ... I use winxp, im hoping that many cards dont have conflicts with it :-?
All I care about is how the card handles video, since I wont require it to worry about audio (at least how I ideally want to use it)
Any cheap cards out there do what I want? Are there any cards that do do that?
If not, of the cheap cards that I put to a vcr, which do you recommend?
Appreciate your time :wink:
Results 1 to 1 of 1
Bizzare problem capturing - NEWBIE
By Aarell in forum Newbie / General discussionsReplies: 2Last Post: 17th Jan 2012, 11:38 -
Newbie question - capturing and converting from DV
By zaspa in forum Newbie / General discussionsReplies: 8Last Post: 31st Aug 2011, 16:56 -
Capturing HD Video -- (NEWBIE)
By PixelBucks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 24th Jun 2009, 12:31 -
Newbie help with capturing !!
By hightimes420 in forum Newbie / General discussionsReplies: 3Last Post: 27th Oct 2008, 16:48 -
Newbie question on Capturing to Encoding
By Lucky19th in forum Newbie / General discussionsReplies: 10Last Post: 16th Jul 2007, 14:09
