Hello,
I'm creating my own collection of TV reports, movies, and so forth. I'd like to remove commercials from the beginning, from the middle, and from the end of the show. I found a number of tutorials on the web, including one on VideoHelp, but to date I'm still unable to get satisfactory results. Here's the list of problems I have encontered so far: My video is rejected (VideoDub), my output video is taking forever to be resampled (Adobe Premiere), or it uses a huge amount of space with nothing to watch (MPEG Video Wizard DVD). If you could help me, I would appreciate it. I suspect the source file in general has a problem. It's saved from either VLC or DVBViewer. Here's a sample 30-sec file. I'd like to know if there's an MPEG error in its content and if you're able to remove parts of the video, like 5 seconds at the beginning, 5 seconds in the middle and 5 seconds in the end, without losing video quality. If you're able to do so with my sample, please let me know how you did.
Thank you,
Results 1 to 15 of 15
Assuming this is a typical sample, the file itself has index issues. Loading the sample into AVI Demux prompted it to point out that it looked like an mpeg file (but obviously isn't clearly marked as one) and that it needed the index rebuilt. Once rebuilt, I could trim it without any problems. It also plays back correctly after have having the index built and being resaved.
I suspect that if you used VideRedo, and ran it through the stream fix first, you could trim it to your heart's content.
I have attached a (roughly) edited version of your sample clip. Note : You will get cleaner cuts from VideoRedo that from AVI Demux, and won't be restricted to key framesLast edited by guns1inger; 18th Apr 2010 at 20:31.
Read my blog here.
Womble MPEG Video Wizard should also work (cut on any frame, only cut GOPs reencoded). They have free giveaways now and then.
I think VideoRedo has a beta with AVC support. For keyframe only cutting of AVC you can try h264TsCutter or TsSniper.
When I edit an MPEG-TS file in AviDemux, and save it, it is unreadable in Windows Media Player (the player freezes), and DVBViewer (the file isn't recognizable). Could you take a look at the edited file and tell me what's wrong, please?
Thanks. -
jagabo: Thanks this was it. How did you find out the container was an AVI?
I'm still having problems: in Avidemux, when I edit a MPG file, sound is always out of sync. If I offset it in the beginning to sync properly, later in the movie, it's still out of sync. If I offset it later in the movie to sync, it's out of sync in the beginning of the movie
Also, I can't edit HD videos, Avidemux crashes.
Could you help me please? Thanks.
Trimming subtitles along with video
By msmirjat in forum SubtitleReplies: 2Last Post: 6th Sep 2011, 03:08 -
Trimming the audio to go along with the video cuts in avisynth?
By mt123 in forum Newbie / General discussionsReplies: 0Last Post: 10th Jan 2010, 04:23 -
Windows Movie Maker. Blank video when splitting, trimming video clips
By rlarden in forum EditingReplies: 2Last Post: 3rd Jul 2009, 07:23 -
Lossless Video Clip Trimming
By azvenigo in forum Newbie / General discussionsReplies: 0Last Post: 10th Mar 2009, 00:01 -
ADS DVD Xpress capture issue 8MM to DVD
By xxnonamexx in forum Capturing and VCRReplies: 1Last Post: 13th Dec 2007, 22:20
