Ok I captured this video at 1920x1200 but it wasn't in HD so its cropped. How can I get rid of the black bars?
This is what it looks like full screen.
Oh yeah Running windows 7 x64 and cheap or free is best.
Read my blog here.
Right now it is in Mp4 I would like to retain the hd quality of it as well. I will give that a try and see how it goes. Thanks Guns1inger
Also I downloaded that program and I hope this is what you are wanting.
Format : MPEG-4
Format profile : 3GPP Media Release 4
Codec ID : 3gp4
File size : 3.53 GiB
Duration : 56mn 3s
Overall bit rate : 9 006 Kbps
Encoded date : UTC 2010-04-14 19:52:48
Tagged date : UTC 2010-04-14 19:52:48
Video
Format : AVC
Format profile : Main@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : avc1
Duration : 56mn 3s
Bit rate mode : Variable
Bit rate : 8 868 Kbps
Width : 720 pixels
Original width : 1 920 pixels
Height : 480 pixels
Original height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 29.970 fps
Minimum frame rate : 29.944 fps
Maximum frame rate : 29.973 fps
Standard : NTSC
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.856
Stream size : 3.47 GiB (98%)
Language : English
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio
Format : AAC
Format version : Version 4
Format profile : LC
Format settings, SBR : No
Codec ID : 40
Duration : 56mn 2s
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Stream size : 51.3 MiB (1%)
Language : English
Encoded date : UTC 2010-04-14 19:52:54
Tagged date : UTC 2010-04-14 19:52:54
You should "capture" the video at it's original resolution. Then crop and resize to the desired final resolution.
Actually that is captured at the original resolution. HBO on Demand dosen't have an HD and the SD is displayed in that boxed up format. I just found out Episodes 1-3 are comming on tonight so I plan to record them so I'll just have to wait till 4 is replayed or upscale it.
For a 16:9 video letterboxed into a 4:3 frame pillarboxed in a 1920x1080 broadcast you want to crop ~240 lines off the left and right sides, and ~132 pixels off the top and bottom. That leaves you with a 1440x816 frame. What you do from there depends on where the video is going.
Why won't my HD video scale up to full screen?
By johnharlin in forum Video ConversionReplies: 7Last Post: 5th Mar 2011, 11:00 -
What is a scale factor?
By rocky12 in forum Newbie / General discussionsReplies: 47Last Post: 22nd Jul 2008, 14:34 -
Making a gray scale
By yogart in forum ComputerReplies: 4Last Post: 24th Nov 2007, 19:40 -
How to add watermark to a video with mencoder or how to scale with FFmpeg?
By ApplePro in forum Video ConversionReplies: 16Last Post: 21st Nov 2007, 09:12 -
off topic - quick question about scale
By waheed in forum Off topicReplies: 2Last Post: 14th May 2007, 00:29
