A friend needs that I recommend/install a hard drive for him. I reviewed the mobo's specs and the SATA connectors on the mobo (there are two of them) are SATA 1 compliant. Will they be able to support SATA 2 or 3 hard drives? Or just SATA 1? Thanks.
You may need a jumper on a SATA 2 drive for it to work on a SATA 1 interface - the drive will act like a SATA 1 drive.
SATA 3 is also backward compatable but how that would perform at SATA 1 speed I dread to think.
(and do not forget that the power connector on a SATA 2 drive is quite different to a SATA 1 which was typically the 4 pin molex.) -
I thought that SATA drives did not have jumpers. Regarding the power connector being different, that adds another complication. Problem is it's hard to find SATA1 drives these days.
Most any PC has a 4 pin Molex for PATA drives, the same as some SATA 1 drives use. And Molex to SATA 2,3 power adapters are common if the PC doesn't have them.
Try it without removing (Or adding) the jumper first. To find out it's correct position if you need to use it, go the the drives manufacturer and check the pinout for that drive. There are other jumper positions there also, mostly for diagnostics.
Another option is to add a PCI SATA 2 adapter card. I would look for one with a Silcon Images chipset. -
Most SATA 2 drives work fine on most SATA 1 controllers. Some have jumpers to limit the transfer rate to SATA 1 speeds. And if you need it, most drives come with a power adapter cable. Don't worry about it.
Regarding transfer rates, only the fastest drives are now exceeding the transfer rate of a SATA 1 controller and even then only across a portion of the drive. Don't worry about this either. -
Thanks for the replies. I will be careful with all these compatibility details (power cable, jumper setting and optional sata adapter card) when purchasing the hard drive.
SATA 6.0 vs. SATA 3.0
By DarrellS in forum ComputerReplies: 7Last Post: 28th May 2011, 02:33 -
how to re-anable my sata icon in win xp sp3 (sata drives not visible in DM)
By deejay.2001 in forum ComputerReplies: 7Last Post: 11th Mar 2011, 09:47 -
Can't get e-sata to work
By DarrellS in forum ComputerReplies: 28Last Post: 31st Jan 2009, 10:35 -
SATA I cables and SATA II
By HatchetMan in forum ComputerReplies: 5Last Post: 4th Feb 2008, 15:06 -
Are all SATA cables the same?
By spiffy in forum ComputerReplies: 4Last Post: 13th Nov 2007, 01:49
