How do i make Virtualdub as portable as possible? (without using VirtualdubPortable, cos that one seems infected with spy ware.)
I'm talking about putting all needed files in one directory.
I don't mean to double post but this seems to be more in place here than purely the codecs forum.
feel free to remove or whatever if u think otherwise.
	Looking for subtitles of: Höök tt0997023, Lime tt0269480, La clé sur la porte tt0077348. tt=iMDb.com Found Desideria tt0081724 subtitle! :-)
	Virtualdub is portable. It unzips into a single folder with a small number of subfolders, including the plugins folder. Install the plugins you need, then copy the base virtualdub folder to a usb key and you are portable. Yes, on each new machine you may be greeted with the first time start up screen, but that is a one off. Unless you have a particularly funky plugin that does require other libraries installed outside the virtualdub folder, you should have no issues running it pretty much anywhere.
 However, as virtualdub does not carry it's own codecs with it, issues such as missing codecs for reading or writing files could still be an issue. There is nothing you can do about this.Read my blog here.
	You're right on the money that I wanna run Vdub from an Usb-stick.
 I don't get why that is an issue? Vdub must get/load the codecs from somewhere, why not from it's own program directory? I don't even see how it could be a legal issue when we're talking about the xvid codec, it's free, which is the one i wanna install on that usb stick.
 Could you please clarify?Looking for subtitles of: Höök tt0997023, Lime tt0269480, La clé sur la porte tt0077348. tt=iMDb.com Found Desideria tt0081724 subtitle! :-)
	If you want an editor with built in codecs try AviDemux. VirtualDub does have built in DV and MJPEG codecs.
	I should clarify that VirtualDub only has built in decoders for DV and MJPEG, not encoders.
 Some other conversion programs that do have built in decoders and encoders include MeGUI and Xvid4PSP. You can install those then copy all the folders to a thumb drive and run them from there. But... you may find that they require particular versions of Microsoft .Net and/or Visual C++ runtime libraries be installed.
	okay, so it's all moot, i found some uni-pc's which allow installation of anything, so ... And I must say, I've used Avidemux, but only when i had to, when VirtualDub was just too picky about which or what files it wanted to stitch together. And it was just a bit odd to use, but that's cos im not used to it. Sometimes I've noticed that I've used Vdub and I'm not really aware of which keys and commands I've used, I've grown so accustomed to it.
 But's likely I'll be forced to use avidemux in the end anyway, so ...
 Thanks, Tj and jagobo!Looking for subtitles of: Höök tt0997023, Lime tt0269480, La clé sur la porte tt0077348. tt=iMDb.com Found Desideria tt0081724 subtitle! :-)
  HowTo add permanent Letterboxed subtitles to video w/ Virtualdub, SRTtoSSABy KneeRow in forum SubtitleReplies: 20Last Post: 13th Feb 2013, 14:05
  Did they ever make a portable flash video player that plays .flv videos?By snafubaby in forum Portable VideoReplies: 0Last Post: 25th Feb 2012, 01:21
  PNSR howtoBy themoog in forum Newbie / General discussionsReplies: 9Last Post: 8th Jan 2012, 12:44
  How to make continuous rotating video with VirtualdubBy frmys in forum EditingReplies: 26Last Post: 19th Aug 2011, 18:24
  Portable Scanner by VuPoint: how do i make scans fit 8x11 letter size ?By vhelp in forum ComputerReplies: 4Last Post: 6th Jun 2010, 17:37
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
