  1. sorry if this is the wrong forum, i set a batch of full disks to bd-25
    and got this error on 2 of them any help would be nice.
    [21:05:11] BD Rebuilder v0.33.04 (beta)
    - Source: JUMPER
    - Input BD size: 40.64 GB
    - Approximate total content: [03:13:35.762]
    - Target BD size: 22.66 GB
    - Windows Version: 6.1 [7600]
    - Audio Settings: AC3=1 DTS=0 HD=0 Kbs=640
    - Error in attempt to multiplex: MUX_00002.meta
    - Can't open file: C:\WORK IN PROGRESS\WORKFILES\00002.track_6656.DTS
    [23:41:57] - Failed to build structure, aborted
    been searching other forums but can only find older ones with no solution
    Moving you to our blu-ray ripping and shrinking section.
    You could also try shrink with avchdcoder.
