Hello there. My computer at home is connected to my 42" plasma TV. I play video files on my computer and watch them on the plasma as my monitor.
I like to use the video player on my computer to stretch the video to fill up the whole screen. I have noticed that video files with the largest frame sizes look the best after they are stretched.
Currently I use hand brake to create video files from DVD's. I want to get the best quality I can, so i was wondering if there is there another free software program besides handbrake which would allow me to create larger frame sizes?
Am I on the right track here?
Any insights you can provide would be appreciated.
Thanks!!
TC
My Dell PC system info.....3.4 Ghz Quad Core i7 processor....... 12 gigs of ram DDR3...... Windows 7 ultimate 64 bit.......video card Nvidia GTX 650
A ripper just rips the video from the DVD. At this point the video frame will 720 x 480 (NTSC) or 720 x 576 (PAL). If you are using Handbrake then you are also converting the video, which is probably resizing as well.
So you have to learn how to use handbrake to make sure it doesn't reduce the resolution too far. Simplest way is to tell it to keep the width 720 pixels and, if necessary, resize the vertical.
Start by looking at what it is currently creating, Use Mediainfo to see what resolution you are getting. If you are asking for a particular filesize, Handbrake may be reducing the resolution to quality higher at the chosen bitrate. The higher the resolution, the higher the bitrate required to maintain the quality.Read my blog here.
DVD-lab frame size
By Burig in forum Authoring (DVD)Replies: 4Last Post: 17th Oct 2011, 11:27 -
How to find a subtitle's characteristics from a DVD (font type, size etc.)?
By thinredline in forum SubtitleReplies: 6Last Post: 5th Feb 2011, 15:20 -
Frame size to use for editing 16:9 footage extracted from a DVD
By jason1123 in forum EditingReplies: 8Last Post: 16th Mar 2010, 20:05 -
VCD movies - I can't find a ripper!
By robsamui in forum Video ConversionReplies: 10Last Post: 18th Mar 2008, 07:20 -
DVD (VOB) Frame Size
By Brosco in forum ProgrammingReplies: 6Last Post: 14th Jun 2007, 22:24
