Help,
I bought some BD-r on ebay that won't work with my GBW-H20L burner. I don't want to make the same mistake twice. What BD-R media works with my burner that is reasonably priced? I found Memorex 32020013358 25GB at Amazon at $35 for 15 and Verbatim 96769 25GB at $32 for 10. Will these work or is there a better chose?
Well, I have never burned a BD disc, but Memorex DVD media is pretty bad. Before I learned anything about different DVD manufacturers, I would just buy whatever was cheapest or easiest to get at local stores. I had more problems with Memorex than anything I ever bought. Verbatim is considered to be one of the consistently best DVD and CD manufacturers. If I was going to gamble my money on BD discs, I'd buy Verbatim. LG is not considered a high quality DVD brand. There's not a lot of info yet on BD disc quality, but I'd suggest going with Verbatim as they have a good record for other media and LG and Memorex do not.
I don't recommend buying any media on Ebay. You have no way to know what you are getting. It could be that LG is simply a low quality BD disc manufacturer or even that your LG BD discs are bootlegs. Buy from reputable vendors like rima.com or supermediastore.com.
How To Convert DVD Media Made From VHS Media For Sharing Online
By BlazingSpeed in forum Video Streaming DownloadingReplies: 0Last Post: 11th Dec 2010, 14:20 -
Conflicting Claims: Can LG GGC-H20L write DL (50 GB) Blu-Ray discs or not?
By ambushed19 in forum Blu-ray RippingReplies: 14Last Post: 4th Apr 2010, 21:40 -
lg gww h20l and possible failure to write data
By angel40204 in forum Blu-ray RippingReplies: 10Last Post: 27th Feb 2010, 20:55 -
DVDFab HD Decypter fails to recongnize Blu Ray movie in LG (GGW-H20L)
By ppurdue in forum DVD & Blu-ray WritersReplies: 4Last Post: 14th Aug 2009, 05:55 -
LG ggw H20L...
By BDR in forum DVD & Blu-ray WritersReplies: 6Last Post: 27th Feb 2008, 10:54
