Greetings...
I have an LG IQ (800x480) Smartphone with Windows Mobile 6.5. I am trying to convert AVIs ("extracted" from YouTube) to WMVs to play on my phone. They seem to come out too choppy or too grainy depending on the settings I use. I have tried playing WMVs which I converted for my Cowon D2+ (320x240, "Auto High Quality" settings)... and they play smooth, but the quality is a bit lacking. I am using the Free Zune Video Converterfrom Pazera.
I have not been able to get smooth playback on a WMV yet, having started from 800x480, 1500bit, 30FPS, now down to 350x210, 500bit, 14.985FPS.
My question: What settings are optimal for this? What setting should I be turning up/down for smoothest playback without the graininess being unwatchable?
PS: Using WMVs for file size/ease of use.
Thanks...
Results 1 to 13 of 13
Just my 3 dollars ( yes, inflation is evil
The "best" ways to convert any video to WMV are:
--- use WmNicEnc + an intermediate AVS file ;
OR...
--- use cscript.exe + WmCmd.vbs + an intermediate AVS file ;
in either case, one should always choose the "2-pass + unconstrained bitrate" mode,
to ensure that NO frames will be ever dropped/duplicated by the stupid
Windows media codecs.
Each source compresses differently. Sorry, there areMy question: What settings are optimal for this?
no "prêt-à-porter" solutions for "optimal" results.
Your device is not so "smart", then.I have an LG IQ (800x480) Smartphone with Windows Mobile 6.5.
Thanks for the help... unfortunately, I have AVI files to convert.
OK, when I run WmEnc, I only get the option to input AVS files... do I just change to "All Files" and select the AVIs? Also, I don't see the options ("2-pass + unconstrained bitrate"} he's talking about. Is that the "MultiPass Encoding" checkbox? By "Unconstrained" Bitrate, he means Constant bitrate?
No, you have to use an AVISynth (.avs) script to stream the files into the encoder, rather than load the AVI files directly. (Of course, AVISynth must be installed, as well.)
I don't actually use WmNicEnc, so I likely wouldn't be of much help with its options.
(Sorry for the late reply - I've been trying to fix one of our computers.)If cameras add ten pounds, why would people want to eat them? -
OK, thanks... this is getting a bit more complicated than I had hoped, but I'd like to get the best method figured out for future conversion as well the tons of AVIs I have waiting. I'll give it a shot this weekend.
Why convert at all? Just use TCPMP to view the AVI's on your phone.
Depending on your device, you may get jerky playback if your video is a higher resolution than your screen, for example watching a 1280x760 movie on a 800x480 screen. If you do need to convert/resize down to 800x480 you can use pocketdivxencoder (beta version 0.4.5) then view it with TCPMP.
Link to pocketdivxencoder_beta.
http://www.pocketdivxencoder.net/EN_index.htm
I think your phone is WVGA so you get this version of TCPMP with a pretty skin.
http://www.modaco.com/content/i8000-verizon-sch-i920-omnia-ii-http-i8000-modaco-com/30.../#entry1212914Last edited by marioval; 21st Apr 2010 at 13:12.
marioval - Thanks, I will try that tool (yes, I have WVGA)... if it can play the AVIs, great! However, for filesize reasons I will still need to convert to WMV at some point...
Why don't you use the mobile DivX-player:
http://labs.divx.com/MobileDownload
I am using it on a HTC Touch HD also with 800x480 WVGA-display resolution and it works well.
As always the video-bitrate determines whether the video is paying smooth or if it stutters (if the bitrate is too high).
Well and I think it only supports DivX-codec- or XviD-codec-encoded videos from version 4 onward, so no
DivX 3 support as this was a hacked Microsoft-codec.
Good luck
Schmendrick -
Will give it a try.
UPDATE: Won't play my AVIs... gives an error msg.Last edited by Darklighter; 27th Apr 2010 at 12:49.
For those who might stumble upon this thread, after more experimentation and research I have discovered .MP4 (MPEG4/AAC) plays perfectly on the IQ, currently converting AVIs to MP4 at 800x480, 1000KBits/s, 30FPS, 128Kbps audio, and it's smooth as silk - looks great.
Thanks to all who helped.
WMV to DV (AVI) for ADVC-300 to TV conversion
By rd0591 in forum Video ConversionReplies: 10Last Post: 19th Nov 2010, 05:03 -
WMV to AVI conversion
By mlimo in forum Video ConversionReplies: 0Last Post: 24th May 2008, 08:55 -
Huge file after WMV to AVI conversion
By windranger in forum Newbie / General discussionsReplies: 8Last Post: 8th Apr 2008, 08:32 -
WMV Conversion to AVI resulting in poorer colors
By timmer545 in forum Video ConversionReplies: 2Last Post: 27th Mar 2008, 02:57 -
WMV video and audio slightly out of sync on conversion to AVI
By Calidore in forum Video ConversionReplies: 8Last Post: 10th Jul 2007, 09:48
