I was hoping to get some advice as to what software you guys would recommend to convert about 100 or more movies from my Canon camera to something smaller than the current MJPEG format which is using about 100meg/1min of video.
I'd like to keep the quality still pretty good and at 640x480 so that I can eventually use them for dvds.
I have about 100 or more of these that are stored in a number of different folders, and best case, I'd like to convert them where they sit, overwriting the current MJPEG version, and unleashing some sort of batch mode to go through the folders and subfolders converting all of them as they are found.
Ideally, I'd like something that I can kick off at night and have it keep track of how far it got in case it gets interrupted, so that the software can continue the process where it left off, or close to it.
I am willing to pay for software that will do this as my wife is constantly taking these vids of our son, they are taking up a ton of room, and I don't see her stopping this anytime soon.
Any help would be greatly appreciated!! Thanks!!!
	I'd put them do a DVD as data first thing. Good quality blank DVDs are cheap(Taiyo Yuden or Verbatim).
 MJPEG is a "small" format....and 640x480 is a "small" size for video+audio.
	Hmm.. I suppose I could go ahead and put them on DVD's to archive them. But, would you leave them as MJPEG to do so? I won't get very many on each disk if I do. Thanks again!
	Of course I would leave them "as is". The quality of the footage will never be better than it is right now
 in it's original state. I've got gigabytes and gigabytes of pics and video of my son. I resize the pics and
 transcode the video to share them with family and friends but I'm sure as hell not going to throw away
 the original afterwards....that's just plain crazy. Storage space is cheap and comes in many forms. I have
 backups of backups of backups.....and none of those backup copies are the resized ones.
	I see.. I guess that I was just assuming that since the camera had so little processing power, that it would not natively save the video in what would be considered an efficient format. I was hoping that there was a compression format that would provide almost identical quality in a much smaller file size, at the cost of processing power. But, if MJPEG is efficient for the quality it produces, I'll pick up a spindle of Verbatim DVDs and start archiving. Thanks!
  Restream MJPEG stream from ip-cameraBy astute in forum Video Streaming DownloadingReplies: 3Last Post: 4th Jun 2016, 10:18
  Canon cameraBy uno in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 20th Apr 2011, 11:54
  New Canon DSLR CameraBy Soopafresh in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 8th Feb 2010, 16:25
  how to batch convert camera video (MJPEG) to xvid?By shun in forum Video ConversionReplies: 1Last Post: 2nd Feb 2010, 16:10
  Memory upgrade needed for TMPGENC DVD Author 3, advice neededBy Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 19:30
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
