I recently started to watch the series Spartacus - Blood and Sand.
I currently have episodes 1 to 6 in 1080i ts transport stream.
When opening in Media info, the 1st and 2nd episode show as having 6 channels, while episodes 3-6 contain only 5 channels (missing the lfe channel)?
Is this correct, or is it a malfunction in Mediainfo ?
Is there someone with a logical explanation for this problem ?
Here is the info Mediainfo gives about these 6 files
eneral
Complete name : G:\Series 1080\Spartacus Blood and Sand 1080i\Season 01\Spartacus Blood and Sand - S01E01.srt
Format : SubRip
File size : 28.4 KiB
Text
Format : SubRip
General
Complete name : G:\Series 1080\Spartacus Blood and Sand 1080i\Season 01\Spartacus Blood and Sand - S01E01.ts
Format : MPEG-TS
File size : 6.18 GiB
Duration : 52mn 43s
Overall bit rate : 16.8 Mbps
Video
Menu ID : 1 (0x1)
Format : MPEG Video
Format version : Version 2
Format profile : Main@High
Format settings, BVOP : Yes
Format settings, Matrix : Default
Format_Settings_GOP : M=3, N=15
Duration : 52mn 43s
Bit rate mode : Variable
Bit rate : 15.2 Mbps
Nominal bit rate : 17.6 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.245
Stream size : 5.61 GiB (91%)
Audio
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Duration : 52mn 43s
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Stream size : 145 MiB (2%)
Text
ID : 33 (0x21)608-1
Menu ID : 1 (0x1)
Format : EIA-608
Muxing mode : MPEG Video / EIA-708
Muxing mode, more info : Muxed in Video #1
Duration : 52mn 43s
Stream size : 0.00 Byte (0%)
General
Complete name : G:\Series 1080\Spartacus Blood and Sand 1080i\Season 01\Spartacus Blood and Sand - S01E02.srt
Format : SubRip
File size : 32.7 KiB
Text
Format : SubRip
General
Complete name : G:\Series 1080\Spartacus Blood and Sand 1080i\Season 01\Spartacus Blood and Sand - S01E02.ts
Format : MPEG-TS
File size : 6.05 GiB
Duration : 51mn 13s
Overall bit rate : 16.9 Mbps
Video
Menu ID : 1 (0x1)
Format : MPEG Video
Duration : 51mn 13s
Bit rate : 15.3 Mbps
Resolution : 8 bits
Colorimetry : 4:2:0
Bits/(Pixel*Frame) : 0.247
Stream size : 5.49 GiB (91%)
Audio
Menu ID : 1 (0x1)
Format : AC-3
Duration : 51mn 13s
Bit rate : 384 Kbps
Stream size : 141 MiB (2%)
Text #1
ID : 33 (0x21)608-0
Menu ID : 1 (0x1)
Format : EIA-608
Duration : 51mn 13s
Text #2
Menu ID : 1 (0x1)
Format : EIA-708
Duration : 51mn 13s
General
Complete name : G:\Series 1080\Spartacus Blood and Sand 1080i\Season 01\Spartacus Blood and Sand - S01E03.srt
Format : SubRip
File size : 34.9 KiB
Text
Format : SubRip
General
Complete name : G:\Series 1080\Spartacus Blood and Sand 1080i\Season 01\Spartacus Blood and Sand - S01E03.ts
Format : MPEG-TS
File size : 5.28 GiB
Duration : 54mn 9s
Overall bit rate : 14.0 Mbps
Video
Menu ID : 1 (0x1)
Format : MPEG Video
Duration : 54mn 9s
Bit rate : 12.6 Mbps
Nominal bit rate : 13.2 Mbps
Standard : NTSC
Resolution : 8 bits
Colorimetry : 4:2:0
Bits/(Pixel*Frame) : 0.203
Stream size : 4.77 GiB (90%)
Audio
Menu ID : 1 (0x1)
Format : AC-3
Duration : 54mn 9s
Bit rate : 384 Kbps
Channel(s) : 5 channels
Stream size : 149 MiB (3%)
General
Complete name : G:\Series 1080\Spartacus Blood and Sand 1080i\Season 01\Spartacus Blood and Sand - S01E04.srt
Format : SubRip
File size : 30.7 KiB
Text
Format : SubRip
General
Complete name : G:\Series 1080\Spartacus Blood and Sand 1080i\Season 01\Spartacus Blood and Sand - S01E04.ts
Format : MPEG-TS
File size : 4.60 GiB
Duration : 47mn 11s
Video
Menu ID : 1 (0x1)
Format : MPEG Video
Duration : 47mn 11s
Standard : NTSC
Resolution : 8 bits
Colorimetry : 4:2:0
Stream size : 4.16 GiB (90%)
Audio
Menu ID : 1 (0x1)
Format : AC-3
Duration : 47mn 11s
Bit rate : 384 Kbps
Stream size : 130 MiB (3%)
General
Complete name : G:\Series 1080\Spartacus Blood and Sand 1080i\Season 01\Spartacus Blood and Sand - S01E05.srt
Format : SubRip
File size : 35.7 KiB
Text
Format : SubRip
General
Complete name : G:\Series 1080\Spartacus Blood and Sand 1080i\Season 01\Spartacus Blood and Sand - S01E05.ts
Format : MPEG-TS
File size : 5.20 GiB
Duration : 53mn 17s
Video
Menu ID : 1 (0x1)
Format : MPEG Video
Duration : 53mn 16s
Standard : NTSC
Resolution : 8 bits
Colorimetry : 4:2:0
Stream size : 4.69 GiB (90%)
Audio
Menu ID : 1 (0x1)
Format : AC-3
Duration : 53mn 16s
Bit rate : 384 Kbps
Stream size : 146 MiB (3%)
General
Complete name : G:\Series 1080\Spartacus Blood and Sand 1080i\Season 01\Spartacus Blood and Sand - S01E06.srt
Format : SubRip
File size : 50.0 KiB
Text
Format : SubRip
General
Complete name : G:\Series 1080\Spartacus Blood and Sand 1080i\Season 01\Spartacus Blood and Sand - S01E06.ts
Format : MPEG-TS
File size : 5.07 GiB
Duration : 51mn 58s
Video
Menu ID : 1 (0x1)
Format : MPEG Video
Duration : 51mn 57s
Standard : NTSC
Resolution : 8 bits
Colorimetry : 4:2:0
Stream size : 4.58 GiB (90%)
Audio
Menu ID : 1 (0x1)
Format : AC-3
Duration : 51mn 57s
Bit rate : 384 Kbps
Stream size : 143 MiB (3%)
NOTE: I use a script to rename the files and subtitles.
Many 5.1 mixes for domestic use don't have an LFE, or if they do, it is empty. This is not true for all, but it is for many. The reason they don't is because the cut over for most domestic amps is set at a level whereby the bass tones in the normal channel sis enough to trigger the sub woofer, and therefore an LFE channel is superfluous.
Of course without knowing where these came from, it is hard to say why they are the way they are. If you downloaded them they may have been created by someone who simply screwed up.Read my blog here.
Let's say I want to convert these files to a more convenient format, including various subtitles, like mkv.
Is there a way to convert the audio to 5.1 channel ac3 ?
Sony Vegas : How to restore LFE channel default setting?
By Bonie81 in forum Newbie / General discussionsReplies: 0Last Post: 22nd Jan 2011, 18:52 -
Converting MKVs with several 6 channel audio streams to iPod...
By planetofthemage in forum Video ConversionReplies: 4Last Post: 15th Sep 2010, 05:06 -
NO LFE channel in TS transport streams ?
By s1lenc0r in forum Video ConversionReplies: 1Last Post: 17th Apr 2010, 07:02 -
video in my Windows Movie Maker project was missing an audio channel
By DaneClark in forum Newbie / General discussionsReplies: 0Last Post: 7th Aug 2009, 19:52 -
DVD missing left channel...
By xichael in forum DVD RippingReplies: 2Last Post: 31st Dec 2008, 16:13
