It keeps saying I don't have Haali installed even though I do have the latest. ini file has nothing I can change
Yes, you can edit the RipBot264.ini in notepad, then save with the same extension. Try adding ' CheckRequiredSoftware=0 ' That used to be in the old .ini, but I don't see it anymore, so it may not work.
What I have done is to uninstall all the required RipBot components, reboot, then install them again, then install Ripbot and see if that works. -
I thought that might be the case as the line has been removed with newer versions. I would go with the program versions that RipBot wants. If the author updates the program, then maybe newer versions of programs may work. Or maybe the newer versions of the programs don't work without extensive rewriting of the RipBot program.
I installed the version required and it's picked up now. Seems like an unnecessary check
Mac version of VLC is less functional than the Windows and Linux version
By HitTheRoad in forum MacReplies: 12Last Post: 30th Oct 2011, 03:48 -
SUPER version 39 is broken - reinstall older version?
By castalla in forum Video ConversionReplies: 7Last Post: 3rd Nov 2010, 18:20 -
Error Checking CD's
By Nitro89 in forum AudioReplies: 30Last Post: 8th Nov 2009, 23:58 -
Quality Checking copies
By OldPhart in forum MediaReplies: 14Last Post: 1st Oct 2008, 07:31 -
where to download old version of dvd fab??? error in new version
By willhenderson in forum Newbie / General discussionsReplies: 1Last Post: 1st Dec 2007, 16:00
