Hello all,
I'm a bit new at this, so here's a chance to show off your stuff. I'm hoping to remove a horizontal tear that appears for about 30 seconds on a VHS tape I have, prior to capturing. (Is it still considered tearing if it's not at the very top or bottom of the screen?) The tape is 20 years old and I believe recorded at SP speed. The tear appears about 1/3 down from the top of the screen and fades in and out at the same points everytime it's played back. I'm running a JVC 9911 through an AVT-8710 and have tried some of the different player settings to try to remove it - to no avail. I assume it's there due to a bit of tape damage.
I'm just looking for some suggestions for determining the actual cause and how to eliminate/minimize its appearance. I've read here many times that the Panasonic DMR-ES10 (which I don't have) removes tearing/flagging, but maybe what I have doesn't sound like a tearing issue to you. I can try to provide a sample later.
Thanks!
Results 1 to 1 of 1
How can I correct severe tearing during VHS capture?
By Sparrowhawk in forum Capturing and VCRReplies: 11Last Post: 3rd Apr 2011, 18:31 -
Intensity Pro Screen Tearing.....
By luc2010 in forum Capturing and VCRReplies: 11Last Post: 7th Sep 2010, 17:33 -
Small picture in middle of screen - burned DVD in Nero Vision
By bigj7489 in forum Newbie / General discussionsReplies: 1Last Post: 29th Apr 2008, 18:20 -
help with VHS tapes with lines int he middle
By curt1sw in forum RestorationReplies: 6Last Post: 14th Dec 2007, 08:51 -
Removing a block from a VHS tape
By dreamydiva in forum Newbie / General discussionsReplies: 3Last Post: 14th Jul 2007, 23:12
