I use an older laptop to stream DivX movies--I coonected my HDTV with a VGA cable and the box that is showing the DivX content shows up just fine on the PC's Screen, but shows blank on the HDTV. All other content from the PC shows up fine on the HDTV (Netflix streams, flash-based content).
Any suggestions to fix this would be appreciated
(I'm particularly confused why the HDTV doesn't just show the same thing that's on the laptop screen)
Thanks,
Jon
It sounds like a video overlay issue((see http://en.wikipedia.org/wiki/Video_overlay ). So try change the hdtv monitor to the primary monitor in windows display options and you should then get video on the hdtv but not on the laptop screen.
And it's just your divx video that uses video overlay, the other flash video does not use it. -
Thx for the reply.
I tried to do this, but the HDTV is not showing up as a separate monitor (when i chose "Identify," both laptop and HDTV displayed a #1) -
Streaming PC Desktop To HDTV
By frmys in forum Video Streaming DownloadingReplies: 2Last Post: 27th Jan 2011, 09:56 -
Live video streaming, is it possible with security HDTV IP cameras?
By Woohooo in forum Newbie / General discussionsReplies: 1Last Post: 17th Jun 2010, 16:58 -
Streaming HD movies to HDTV from downloaded Blu-Ray source
By embreeb in forum Media Center PC / MediaCentersReplies: 1Last Post: 12th Dec 2008, 04:46 -
Divx files on an HDTV?
By snaithbert in forum DVB / IPTVReplies: 15Last Post: 1st Jun 2008, 04:35 -
Streaming from PC to HDTV through ethernet
By Mastablastacious in forum Media Center PC / MediaCentersReplies: 19Last Post: 16th Jan 2008, 22:53
