Here's a problem I had never run into before, I was ripping Sparticus the other day, a 4 hour movie, and the resulting audio file was 2.13g, tmpgenc would not open the audio file at start of encode, all it said was audio error, I narrowed it down to the file exceding 2gb, I run windows xp and use the ntfs file system so it is deffinatly a tmgenc bug. I got around it by frame serving in two parts using dvd2avi. Just a word of warning for anyone seeing this problem in the future.
BTW, using an external audio tool does not fix the problem either, that was the first thing I tried, using toolame I got the same error at encode start.
which version of tmpgenc?
to which format are you trying to encode?As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
this was 2.5 plus, the commercial version, and I was encoding to vcd using the vcd film template. But I also tried the svcd format just to test, same result. Like I said, it was the first time I had seen this problem as it is rare you ever have an audio file go over 2gb in a dvd rip.
hey guys, i've run into problems ripping movies over 3 hrs long...i.e. titanic, green mile, godfather series....
an easy i do is to just split the .vob files into two groups and encode them like 2 separate movies...now the .wav files from the two separate groups of vob files will be small enough for tmpgenc to handle
ffmpeg output 2gb limit? Is there one? ffmpeg stops encoding h264 @ 2gb
By BrainiakZ in forum Video ConversionReplies: 14Last Post: 30th Mar 2011, 12:04 -
Which one is better? Shrink 4GB movie to 2GB MPG or 2GB Xvid?
By volam in forum Video ConversionReplies: 4Last Post: 13th Jun 2009, 01:20 -
Remove 4032mb Limit On TMPGENC 4.0.
By Anakin in forum Video ConversionReplies: 1Last Post: 28th Sep 2008, 18:41 -
Converting and splitting 2GB MPG file
By mohalfares in forum Video ConversionReplies: 3Last Post: 2nd Sep 2008, 12:47 -
File Size Limit With TMPGEnc Plus 2.5 or MPEG-2?
By RABinMS in forum Video ConversionReplies: 5Last Post: 10th Feb 2008, 14:30
