Hi --
I'd like to know if you can use .srt subtitles with DVDit 6 PRO.
If not, is there a way to convert them to something that works with it?
Thanks!
"It's more like a big ball of wibbly-wobbly, timey-wimey... stuff"
The 10th Doctor from "Blink" -
I doubt that. But you can use subtitle workshop and convert the srt to a format that dvdit supports like "Sonic DVD Creator". See also http://forums.support.roxio.com/lofiversion/index.php/t15988.html .
OK I guess that means that I have to strip the subs off of the original video file. It's an mkv file. Can you tell me how to strip the subs?
Thanks!"It's more like a big ball of wibbly-wobbly, timey-wimey... stuff"
Mpeg2 files taking up more space than they should in DVDit Pro?
By Veepa in forum Authoring (DVD)Replies: 7Last Post: 12th Mar 2010, 19:18 -
Replacement for DVDit Pro HD 6.3 Final
By GrampaD in forum Authoring (Blu-ray)Replies: 2Last Post: 11th Oct 2009, 11:04 -
Subtitle Sync Problems in DVDit Pro
By aquaorbis in forum SubtitleReplies: 0Last Post: 5th May 2009, 22:40 -
Has anyone used Sonic Scenarist or DVDit pro HD?
By jbandy1 in forum Authoring (Blu-ray)Replies: 16Last Post: 18th Feb 2009, 01:08 -
DVDit Pro HD and Sript error in activation
By arturjose in forum Authoring (DVD)Replies: 1Last Post: 19th Nov 2007, 00:51
