Hi all!
So it opens in VLC, but nothing else, I guess my question is, is there another program out there that can read this file and export it out to something else?
Another question would be, why is this file acting this way? I have a potential client that has a boat load of these exact same types of clips they want me to work with, any help?
Thanks!
You can convert in vlc. File->Convert/Streaming. Or else try all-in-one-converters like winff, format factory, xmedia recode.
If you want more help then give MORE information about the source file. Open the file in mediainfo to get all details. -
It's possible that you simply don't have the correct codec for it, or you lack a proper mp4 player/encoder to deal with the video.
It's also possible it's a password protected or secured video encoded with Divx.
You might want to try getting a h.264 codec installed. Maybe Xvid? Maybe install FFDshow, I'd probably try that first.
If it's a secured video you might be sol.
VLC Video Player won't open subtitles
By snafubaby in forum Software PlayingReplies: 2Last Post: 14th May 2011, 23:47 -
Can't open MKV file ripped from DVD - Plays in VLC but not in edit programs
By dsunbury in forum DVD RippingReplies: 3Last Post: 7th Apr 2011, 06:21 -
Add VLC to "Open With"
By Digiface in forum Software PlayingReplies: 14Last Post: 6th Feb 2008, 00:30 -
unable to open mpeg-2 video
By yic17 in forum Video ConversionReplies: 1Last Post: 27th Sep 2007, 15:41 -
VLC closes when I attempt to open Video_TS Folder
By costello in forum MacReplies: 12Last Post: 10th Aug 2007, 10:26
