So that's the problem: I got a video file (AVI) and the audio track contains sound that is quite to low. What program do you use to normalize audio and raise the volume? Do you extract the audio track first and edit it or is there any solution to do it while working on the video?![]()
Demux the audio (use eg VirtualDub, Avidemux).
If the audio is MP3, you can normalise it without recompressing using using MP3Gain or MP3DirectCut and then mux it back.
If any other format, use an audio editor like Audacity.
what is the best way to normalize an ac3 audio?
By sgbd in forum Video ConversionReplies: 1Last Post: 24th Sep 2010, 14:46 -
Is there a way to batch normalize audio of MPG2
By mehnihma in forum AudioReplies: 3Last Post: 6th Mar 2010, 00:15 -
Normalize audio - batch possible?
By lj01 in forum Newbie / General discussionsReplies: 4Last Post: 25th Jul 2008, 19:19 -
Normalize AC3 Audio
By dridge in forum AudioReplies: 3Last Post: 26th Nov 2007, 12:12 -
Dummy audio file in silent DVD?
By elkfir in forum Authoring (DVD)Replies: 4Last Post: 2nd Oct 2007, 23:24
