Hi,
I'm an newbie with old-time equipment. I have several issues I'd like help with. The first is simple. What's a good VCR head cleaner that doesn't cost a lot? I'll be using it on my very old, but still running fine Panasonic TV with built-in VCR. I did a search for other posts, but they were all 2+ years old.
Second, I recently hooked up a Magnavox TV with a Converter Box and a Cyberhome VCR/DVD. Videos & DVDs will play, but I cannot record a VHS tape.
Third, I want to view movies on my TV that I get on my PC. Is there a relatively easy and/or cheap way to do this?
Lastly, I am thinking of buying a new TV to use without a converter. Again, gotta be very reasonable. Any recommendations?
Thanks.
Last edited by SHIKISMOM; 15th Apr 2010 at 06:37. Reason: Add information re: search done at your site
If you are serious, use a standalone vcr if at all possible. Most cleaning tapes are meh. Here's a good how-to link.
http://www.hometheaterhifi.com/volume_5_1/diy6vcrcleaning.html
Never, ever clean the video heads with a vertical motion. Please remember this law.
Soon you'll be cleaning heads like a wizard.
Read this: http://www.digitalFAQ.com/forum/showthread.php/panasonic-ag-1980-2108.html?p=11353#post11353
It covers both "How to Clean VCRs" and "How NOT to Clean VCRs" all in one page.
Those combo VCR+TV units are a pain to work with, good luck.Want my help? Ask here! (not via PM!)
question about demagnetizing audio head on VCR to improve audio
By jimdagys in forum Newbie / General discussionsReplies: 3Last Post: 29th Aug 2008, 17:47 -
VHS Head Cleaning -- How do I know if the VCR needs it?
By KeepItSimple in forum RestorationReplies: 20Last Post: 23rd Mar 2008, 22:10 -
JVC HR-J7020UM Hi-Fi 6 Head VCR VHS -too good to be true?
By barkingcat in forum Capturing and VCRReplies: 4Last Post: 4th Feb 2008, 13:11 -
Whats the best software uninstaller & registry cleaner ?
By mol3000 in forum ComputerReplies: 5Last Post: 2nd Oct 2007, 03:03 -
Video head cleaning & capture
By MTD in forum Newbie / General discussionsReplies: 8Last Post: 9th May 2007, 20:56
