  1. Well, hello folks, here begging and hoping to get a fix or something around with this very common problem around the encoding field but it seem there is not topic related to my events and I donīt specifically know what could be causing this A/V sync problem with StaxRip(A GUI that Iīm using all the time now cus of its good work at giving me tremendous quality-wise in my results) where as encoding with MeGUI it doesnīt (fit to say that the same happen with almost every GUI I have issued with but MeGUI), if I ainīt wrong, this kind of problem is the progressively kind, since constant are the easier to deal with, but this one doesnīt matter if I addresses a certain ms in Media player classic, it goes out of sync later on...Kinda tired now of this errors.
    Well the root of this happening originate at the attempt of re-encoding to a low size output into a MKV container an anime series I have had in my HD a good time now with the idea of sharing it further and by re-searching the matter, seem like an Audio track with VBR aka variable bit-rate mode cause this kind of issues almost most of the time and sincerely donīt know if any other thing may cause that as well, but I want to ask...
    How can I solutionate this kind of problem with StaxRrip?, and why MeGUI doesīt give me that problem and staxrip does...? there has to be something Iīm doing wrong with StaxRip, have to be known I have fallow almost every form of issueing this happening around the net, extracting audio and then muxing after, encoding with megui from VBR to Adaptive or Constant(I ainīt sure of this though, I mean if encoding the audio with constant setting would change the VBR mode of the source) and finally with vmod...someone adviced me to use sony vega for syncing but I ainīt sure as well, any tool that use to deal with that?
    Well, anyway Here are the fileīs specs and the source itself as well as the differents results I get throughout encoding with MeGUI and StaxRip at the same settings(where StaxRip successfully give me less size and better quality).
    Format: MKV
    Quality: Dvd Rip
    Audio: English
    http://www.megaupload.com/?d=LPUAZ254
    General
    Complete name : D:\STB DOWNLOADS\- JD DOWNLOADS\The tower of Druaga\Tower of Druaga ep 01.mkv
    Format : Matroska
    File size : 252 MiB
    Duration : 24mn 41s
    Overall bit rate : 1 427 Kbps
    Writing application : HandBrake 0.9.3
    Video
    Format : AVC
    Format profile : High@L3.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 5 frames
    Muxing mode : Container profile=Unknown@3.0
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 24mn 41s
    Nominal bit rate : 1 500 Kbps
    Width : 718 pixels
    Height : 480 pixels
    Display aspect ratio : 16:9
    Original display aspect ratio : 16:9
    Frame rate : 29.970 fps
    Resolution : 8 bits
    Colorimetry : 4:2:0
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.145
    Writing library : x264 core 65
    Encoding settings : cabac=1 / ref=5 / deblock=1:2:2 / analyse=0x3:0x133 / me=umh / subme=9 / psy_rd=1.0:1.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-4 / threads=6 / nr=150 / decimate=1 / mbaff=0 / bframes=6 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / keyint=300 / keyint_min=30 / scenecut=40(pre) / rc=2pass / bitrate=1500 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
    Color primaries : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
    Transfer characteristics : BT.709-5, BT.1361
    Matrix coefficients : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
    Audio
    Format : AAC
    Format version : Version 4
    Format profile : LC
    Format settings, SBR : No
    Bit rate mode : Variable
    Codec ID : A_AAC
    Duration : 24mn 41s
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Language : English
    Menu
    00:00:00.000 : Chapter 1
    00:01:35.219 : Chapter 2
    00:03:05.634 : Chapter 3
    00:11:15.632 : Chapter 4
    00:22:55.598 : Chapter 5
    00:24:25.622 : Chapter 6
    Staxrip Resultīs spec(The one with A/V sync problems)
    General
    Complete name : D:\STB DOWNLOADS\- JD DOWNLOADS\The tower of Druaga\Tower of Druaga ep 01 [by Stb].mkv
    Format : Matroska
    File size : 77.3 MiB
    Duration : 24mn 41s
    Overall bit rate : 437 Kbps
    Encoded date : UTC 2010-04-13 23:11:52
    Writing application : mkvmerge v3.3.0 ('Language') built on Mar 24 2010 14:59:24
    Writing library : libebml v0.8.0 + libmatroska v0.9.0
    Video
    Format : AVC
    Format settings, ReFrames : 6 frames
    Duration : 24mn 41s
    Width : 640 pixels
    Height : 464 pixels
    Display aspect ratio : 1.379
    Resolution : 8 bits
    Colorimetry : 4:2:0
    Writing library : x264 core 92 r1510 33d382a
    Encoding settings : cabac=1 / ref=6 / deblock=1:1:1 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=0.40:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=5 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / wpredp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=23.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:0.60
    Audio
    Format : AAC
    Format profile : LC
    Format settings, SBR : Yes
    Format settings, PS : Yes
    Codec ID : A_AAC
    Duration : 24mn 41s
    Title : English
    Language : English
    And finally MeGUIīs results(The one w/e sync problems but less quality..maybe a bad setting of mine cause that)
    General
    Complete name : D:\STB DOWNLOADS\PROGRAM-SOFT\New folder\Tower of Druaga ep 01._new[By stb]-muxed.mkv
    Format : Matroska
    File size : 84.5 MiB
    Duration : 24mn 41s
    Overall bit rate : 478 Kbps
    Encoded date : UTC 2010-04-14 14:30:28
    Video
    Format : AVC
    Format settings, ReFrames : 3 frames
    Duration : 24mn 41s
    Width : 640 pixels
    Height : 432 pixels
    Display aspect ratio :16:9
    Resolution : 8 bits
    Colorimetry : 4:2:0
    Writing library : x264 core 93 r1538 bd72d46
    Encoding settings : cabac=1 / ref=4 / deblock=1:1:1 / analyse=0x3:0x133 / me=umh / subme=6 / psy=1 / psy_rd=0.40:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=8 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / wpredp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=23.5 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
    Audio
    Format : AAC
    Format profile : LC
    Format settings, PS : No
    Codec ID : A_AAC
    Duration : 24mn 41s
    Menu
    00:00:00.097 : en:00:00:00.097
    And where is the spoiler button? would save lot of space and organization, a lot of thanks in advance, and please need some advice here..almost forfeiting.
  2. No one can help here?
    Some advice would come handy, at least can someone tell me how to addresses this kind of bitrate mode in source...since tried mediainfo and nothing, it doesnīt say it is varaible but after the proccess of encoding is done which result of a waste of effort and time..that way I could avoid handling with suchs kind of hassles.
    Please I would be soo grateful to you.
    Mar 2008
    I took a look at the file. First thing I did was to use MKVmerge and saved it to a new MKV file.
    Second, noticed it had a mod 2 width (718) possibly problematic. I downloaded the latest Beta of Staxrip,
    but as you said, it ended up out of sync.
    I used directshowsource in Avisynth and resized it to 704/400 in the script. Even though convertfps was true,
    the converted file was still out of sync. There are experienced Avisynth users on this forum that may be able to help further.
    Take a look at the procedure on this page, it talks about using mkv2vfr to generate an AVS script
    to retime the variable frame rate source.
    http://edwardk.info/wmv2avi/
    Or use directshowsource2 as mentioned on this page:
    http://forum.doom9.org/showthread.php?t=134275
    Here's a script example:
    LoadPlugin("F:\Program Files\AviSynth 2.5\plugdlls\avss.dll")
    dss2("f:/tod.mkv",fps=23.976)
    lanczosresize(704,400)
    Here's one I did:
    http://www.mediafire.com/download.php?jmnm1ejeftz
