Hello:
I am trying to make a backup of an European DVD movie to a DVD backup but every time I insert the DVD I get the error "Cannot play this DVD because of zone restrictions".
I selected region free on dvdshrink options but still cannot watch the DVD.
Anyone knows what can I do to be able to watch this movie on any DVD player?
The DVD player is from USA.
The issue goes beyond region settings alone. You are attempting to play a PAL system DVD in an NTSC system player. Do a search on PAL and NTSC, as I have neither the time nor energy to explain.
i had a same problem in branded player SONY and TOSHIBA.
while unbranded cheap DVD players play all very well. -
You might try re-ripping the dvd using dvdfabhddecrypter and see if you get better results.
Sony and Toshiba are notorious for the "Zone Restrictions" message even when that is not really what the issue is. Since your player is from the USA, it sounds like the problem is that it's refusing to play a PAL DVD regardless of the region code.
If you do get a player that will play PAL DVDs regardless of region, you will run into other obstacles. Will the DVD player convert the PAL disc to NTSC in order to be shown properly on your NTSC television? If not (meaning the player will only output PAL), will your television display the PAL signal properly?
How to burn .avi to dvd-r to watch on a dvd player
By ncastro23 in forum Newbie / General discussionsReplies: 5Last Post: 16th Apr 2011, 17:09 -
Panasonic DVD Recorder (DMR E75V) security dvd player restrictions
By paulmy in forum Newbie / General discussionsReplies: 4Last Post: 12th Jan 2011, 12:43 -
Will a BD-player ignore DVD region restrictions?
By suirauqa in forum DVD & Blu-ray PlayersReplies: 6Last Post: 30th Nov 2010, 08:49 -
DVDs burned in Samsung DVD Writer only possible to watch in some DVD Player
By jorgepe in forum DVD & Blu-ray WritersReplies: 9Last Post: 4th Jan 2008, 03:15 -
AVI files to DVD to watch on DVD player
By leegutcher in forum Newbie / General discussionsReplies: 13Last Post: 20th Jun 2007, 03:01
