Dont know if this is the right forum or if importing files is the same as capturing. I also posted other forums. But...
Here is one of many problems I am running into. When I import original video into Adobe Premiere Pro 7.0 it always leaves out a few frames in random spots scattered throughout a clip (I'm guessing this is what is referred to as dropped frames).
I first noticed this when I went to sync the audio mp3 files, which are imported seperatly, to the video clips and found that the audio clips are a few frames longer; and the audio/video don't match up.
I was hoping someone could shine some light onto why this is happening and what can be done to remedy it. I've fiddled around with differnt settings when loading a new project with no success.
I am importing the origina video from a folder on my desktop. It is MPEG-2 format and came from my Sony Handycam DCR SR45 camcorder. Below are the properties for the video according to a video player on my computer.
Video:
MPEG-2 Video
720x480 (16:9)
29.97fps 9100Kbps
Audio:
Dolby AC3 48000Hz stereo 256Kbps
P.S.
I've recently been told that MPEG-2 files are not ideal for video editing. I've also been told that Premiere Pro doesn't recognize AC3 audio, which is why I am importing the audio seperatly as mp3 files that I have created in another program. Also I've been told that the camcorder I use is not ideal for editing purposes.
So, if anyone sees any reasons to disagree or concur with these statements, please let me know. But as for right now, I currently have existing video from this camcorder that I MUST make work in Adobe Premiere Pro, so please help me work with what I got. Thanks.
Use VirtualDub with MPEG plugin, convert to lossless HuffYUV or uncompressed AVI.
Easy as that.
Adobe Premiere 7 is also known as Premiere Pro 1.0.
It is very old now (2003) and never knew of MP3. Also AC3 wasn't supported for import.
If you want to use an old version of Premiere, you need to prep the files into formats v7 understands.Last edited by edDV; 15th Apr 2010 at 02:11.
http://www.kiva.org/about
Continued failure at importing audio from a DVD into Adobe Premiere Pro CS5
By msp1518 in forum AudioReplies: 0Last Post: 11th Aug 2011, 14:44 -
Importing video/audio into Adobe Premiere Pro CS3
By JCW2001 in forum EditingReplies: 26Last Post: 15th Jan 2011, 20:39 -
FPS-related problems in Premiere when importing a video (solved)
By quandore in forum EditingReplies: 4Last Post: 4th Nov 2010, 06:04 -
Video problem in adobe premiere pro 1.5
By saifshuvo in forum EditingReplies: 1Last Post: 5th Apr 2009, 14:16 -
Problems with importing converted vob into Premiere Pro
By fishytastic in forum EditingReplies: 6Last Post: 16th Oct 2008, 14:18
