Is it possible to use a wireless usb adapter on the WD TV HD Media Player (WDAVN00) to connect to a PC and play media files?
That model doesn't seem to have Ethernet capabilities. If it doesn't have a regular Ethernet socket, then it doesn't have the needed software to use a USB Ethernet adapter either.
You can load up a custom firmware (GGL WDLXTV) and then load wireless support from storage and you might get wireless Lan working on the original WDTV. I had a go but never got it to work .. far too much jiggery-pokery. However the new WDTV live has an ethernet socket and supports wireless usb sticks.
The electronic components of the power part adopted a lot of Rubycons.
What usb wireless N adapter to get?
By neworldman in forum ComputerReplies: 2Last Post: 3rd Nov 2010, 09:49 -
Need help in order to purchase Wireless USB 2.0 Adapter
By Neil_2004 in forum Video Streaming DownloadingReplies: 2Last Post: 10th May 2010, 15:21 -
Wireless Adapter
By Sakuya in forum ComputerReplies: 13Last Post: 21st Dec 2009, 23:40 -
Sprint/Novatel U727 USB Wireless Internet Adapter
By ahhaa in forum ComputerReplies: 2Last Post: 18th Dec 2008, 15:49 -
USB Wireless lan stronger than Internal wireless?
By Super Warrior in forum ComputerReplies: 11Last Post: 7th Aug 2007, 00:26
