Hi , everyone ,
I want to edit a commercial DVD, taking clips out to use in a presentation. Then burning them onto a dvd , before putting the clips onto a pen drive and show through a projector. Can anyone advise a free or commercial editor that is problem free and easy to use? How easy is this whole process? I have a Ulead studio 10 software,Decrypter,and DVD burner. Do I need anything else? apart from an editor? all assistance welcomed, cheers.
Visionman
Health IS the first Wealth------So do not strain your eyes!
Rip to one vob with dvd decrypter, try import in ulead videostudio(?), edit, save.
Another method that does not require that you rip the entire dvd is dvd shrink, open dvd, in the reauthor part choose the clip you want, export as new dvd. Repeat for all clips. You can then reauthor all those vob clips with the free dvd flick.
And you probably need to use latest dvdfab hd decrypter or anydvd to be able to rip all DVDs. -
Thanks Baldrick, I checked ulead videostudio and its videostudio SE, it came bundled with a usb VHS transfer to computer device. Will follow your advice and see how it goes. cheers , thanks again for the direct and helpful advice.
visionmanHealth IS the first Wealth------So do not strain your eyes!
Mac Guy Needs Windows Help Editing Clips, Authoring DVD
By dizzie in forum Newbie / General discussionsReplies: 2Last Post: 18th Nov 2010, 12:12 -
Downloading YouTube Clips For Editing Purposes
By foochuck in forum Video Streaming DownloadingReplies: 4Last Post: 1st Jun 2010, 02:11 -
editing DVD (vob) clips and creating a new DVD with menus
By gappman in forum Newbie / General discussionsReplies: 1Last Post: 5th Sep 2008, 08:30 -
Best Program for Editing Clips from DVD's
By g1275 in forum Authoring (DVD)Replies: 1Last Post: 24th Aug 2007, 10:47 -
Editing a Commercial DVD to remove a swear word...
By Mattman974 in forum Newbie / General discussionsReplies: 8Last Post: 23rd Aug 2007, 13:42
