I have a WDTV Live that I use to watch my DVD's & Blu-rays. I use DVD Shrink for my standard DVD's. I have had a couple of music DVD's have issues not starting at the beginning of the movie. I am using the uncompressed ISO file that DVD Shrink makes when you use back-up. This has only happened to a couple of these music DVD's. I have tried redoing it several times with same result. Movie does not start at the beginning. I am uses ANYDVD also. I want the best quality file I can get for my WDTV Live. The ISO's are anywhere from 3gb to 8gb in size. Should I use some other software for my standard DVD backup files? Or should I try and convert to a different format then ISO. My WDTV plays the ISO fine. Just some movies don't start right. When I play the ISO's on my PC with VLC player they start at beginning and play fine.
I would start by disabling DVDShrink's encrypting capabilities first if you are running AnyDVD in the background. I've never run into that problem but you never know. DVDShrink has not been updated in YEARS so do not count on it to decrypt your DVDs very well.
Make sure AnyDVD is updated.
"Best Quality" means a straight rip - 1 to 1 copy of your DVD.....DVDShrink can also do that. It doesn't need to shrink.
AnyDVD can also "rip to image"(ISO File). -
WDTV Live Wireless HD streaming/playback problem
By Stealth3si in forum Media Center PC / MediaCentersReplies: 6Last Post: 21st Apr 2014, 03:05 -
Will DVD Shrink shrink an ISO image?
By brassplyer in forum DVD RippingReplies: 26Last Post: 19th Sep 2013, 23:03 -
WDTV - Mkv Ntsc files (on a Pal Machine) Playback Problem
By billybob2007 in forum Media Center PC / MediaCentersReplies: 15Last Post: 26th Sep 2011, 11:36 -
Two wdtv gen 1 questions - usb power options and avchd playback
By yoda313 in forum Media Center PC / MediaCentersReplies: 8Last Post: 5th Jan 2011, 19:18 -
Does the wdtv media player handle dvd pal iso files?
By yoda313 in forum Newbie / General discussionsReplies: 4Last Post: 12th Dec 2009, 13:34
