  1. I have been using SVCD2DVD for a long time and since going to Windows 7 (64 bit) the SVCD2DVD name is hard coded into the beginning of the movie. About 10 or so seconds then it disappears. This never used to happen. Am I doing something wrong or is this the "expected" with the new operating system
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Sounds like you are running the DEMO version rather thatn the registered version. Can you post a screenshot of the program?
  3. [IMG]file:///C:/Users/Gramps/AppData/Local/Temp/moz-screenshot.png[/IMG]Hope the attached is adequate. It did ask for my registration and installed like I remember it to
  4. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Bizarre.... Can you post the log so i can see what is happening? Also can you email me and i will send you a newer build to see if that is the problem?
