Okay so I recorded a news sequence that I want to edit for a school project. I took the DVD out and stuck it in my drive and no files pop-up.
I read something about finalizing a DVD in a Panazonic recorder? Can I just put it back in, hit play and then the finalize button?
Finalize first read the manual for your dvd recorder but if you reinsert the disc you should be able to finalize the disc.
On the EZ-28 if you just put the DVD back in the recorder, let it load and finally push EJECT you will be prompted with a OSD to push REC to finalize disc. After about 2 minutes it will finish and another EJECT will eject your finalized DVD.
You can also navigate the FUNCTIONS, OTHER FUNCTIONS, DVD MANAGEMENT menu's and choose FINALIZE disc, either way does the same thing. -
Panasonic DMR EZ28 Won't Eject Disc, Keeps Turning On & Off
By Garyrajsich in forum DVD & Blu-ray RecordersReplies: 3Last Post: 11th Jun 2011, 18:19 -
Panasonic DMR EZ28 - Tape Feed is Jumpy
By Garyrajsich in forum Capturing and VCRReplies: 3Last Post: 7th Feb 2011, 19:18 -
Pixelation issues with Panasonic DMR-EZ28
By DaneClark in forum DVD & Blu-ray PlayersReplies: 1Last Post: 23rd Apr 2010, 14:27 -
Panasonic DMR-EZ27 and EZ28 switches channels while recording
By dtsb52 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 2nd Jul 2009, 11:59 -
Panasonic DMR-EZ28 Previously Recorded Panasonic DVDs
By Surfmaster in forum DVD & Blu-ray RecordersReplies: 6Last Post: 20th Oct 2008, 20:45
