  1. Member lapetite_66's Avatar
    Apr 2006
    Hi:
    I have the latest version of VirtualDub v.1.9.9 installed. I have the latest version of Quicktime and also have all the plugins installed but for whatever reason I am unable to open MOV files in Virtualdub.
    I keep getting the following error message box(see attachments)
Name:	Virtualdub MOV Error 1.jpg
ID:	1286 Click image for larger version
Name:	Virtualdub MOV Error 2.jpg
    Thanks,
  2. do you have the virtualdub mov plugin?
    https://www.videohelp.com/download/VirtualdubPluginPack.zip
    The latest quicktime (7.6.6) is known to cause issues with several programs. Roll back to an earlier version if you are using it
  3. Member lapetite_66's Avatar
    Apr 2006
    Hi poisondeathray:
    If by the MOV plugin you mean both the quicktime.ini file as well as the Quicktime.vdplugin then yes. As for the actual Quicktime player, I am currently using 7.6.5 (that was the last one I upgraded to a few months ago.
    I also have the other plugins that are needed to enable one to open other types of files. As a matter of fact I just downloaded both plugin packs again(today, 4-13-2010) just in case there might have been some new additions.
    Nov 2002
    You might want to visit the Virtualdub Forum and post the complete crash info text there. Phaeron (Avery Lee) or someone else will be able to help you.
    http://forums.virtualdub.org/
  5. Member lapetite_66's Avatar
    Apr 2006
    Hi Darrells:
    I will do that, thanks.
