I had some VHS home movies copied to a DVD, but the GoVideo has some weird DVD structure that nothing can read. I can play the DVD fine from Windows Media Player, but so far DVD Shrink cannot read it. I want to rip clips from it to a digital format.
I wish I could drag the vobs over but whatever file structure GoVideo put it in, even Windows can't read it. It shows no files on the disc in explorer.
Yes it was finalized, I was able to use FairUse Wizard to do what I needed.
I have a Liteon 5115 and I use ripit4me to rip the video of the DVD+rw disks I use. I have converted over 35 video tapes (mostly non-copyright B-moves) to DVD via this process:
Record at 2 hr speed on DVD+RW's with the Liteon
Rip the movie only to HD using Ripit4me (DVDcrypter and DVDStrink), Run FixVTS on the .vob's
Convert .vob's to .mpg's using VOB2MPG
Use DVDStyler to create a menu and save a .iso
Burn .iso using IMGBurn.
This works very well with single layer disks. For Dual-Layer disks I had to add an extra step:
Make the Menu and dvd using DVDStyler, save as .iso.
Open .iso in DVDStrink and backup as ts folders
Using IMGBurn to set proper layer break; burn.
Problems ripping multiple VRO titles from Samsung created DVD-RW
By brancusi in forum DVD RippingReplies: 5Last Post: 8th Mar 2012, 12:19 -
whats the best printable discs to use for a govideo dvd vcr combo
By zerocoool in forum MediaReplies: 1Last Post: 7th Mar 2010, 23:13 -
GoVideo DVR4100 Firmware Upgrade
By csupan in forum Newbie / General discussionsReplies: 2Last Post: 17th Aug 2009, 21:03 -
GoVideo DVP853 DVD Hack with One For All 4 Remote ??
By culttvguy in forum DVD & Blu-ray PlayersReplies: 1Last Post: 1st Apr 2008, 12:17 -
GoVideo DVD/VCR
By candela in forum DVD & Blu-ray RecordersReplies: 2Last Post: 10th Dec 2007, 09:05
