  1. I have managed to obtain my first DivX which is 799mb I would like to convert this to a VCD through Nero but it is obviously over 80mins long, how do I get it on to two discs ?????
    thanks
  2. Just try it with a 700MB CD-R.
    When you burn VCD, it burns in "raw" mode, thus you should be able to use Nero to create a VCD, encode with it if needed, and burn it.
    Up until 2 weeks ago, I had a 4 year old 2x Richo CD-RW burner that burned VCD's that big with no problem.
    Just give it a whirl.
    Feb 2001
    Berlin, Germany
    The MPEG after conversion will get probably larger than 800 MB.
    Next steps:
    http://www.vcdhelp.com/convert.htm
    http://www.vcdhelp.com/editmpg.htm
    if the videoclip is over 80 mins and you wanna make VCD you must
    1. encode www.vcdhelp.com/convert.htm
    2. cut in to pieces www.vcdhelp.com/editmpg.htm
    3. burn on two cds www.vcdhelp.com/burnmpg.htm
  5. I'm a MEGA Super Moderator Baldrick's Avatar
  6. Great thanks for your help, I got it on two discs, the quality isnt as good i.e. lower resolution but its watchable.. is this the best quality I will get , I think its at 358 x 358 .. ?? maybe
