I am trying to convert a Blu-ray movie to the MKV format. I am using AnyDVDHD to rip an image of the Blu-ray to my hard drive. I then use RipBot264 to try to perform the conversion. I'm able to select the streams to be demuxed, and RipBot264 performs the demuxing. At this point, RipBot264 displays a message on the screen, "Please Wait...Gathering Information" which nevers goes away, and the only screen option available is "Abort." I've uninstalled and reinstalled RipBot264 and the associated programs that need to be installed with RipBot264. I am running Windows Professional 64-bit on my Dell XPS410 (updated to a quad-core processor and 8GB of memory). I've tried converting multiples movies on my desktop computer and laptop, and both computers stall after RipBot264 demuxes the selected streams.
This is driving me crazy. Does anyone have any ideas, or do you have this problem?
When I rip the Blu-Ray to my hard drive using AnyDVD HD, the process creates a BMDV and CERTIFICATE directory. With RipBot264, I select the largest mt2s file in the STREAM directory inside the BMDV directory as input. It appears that the demuxing works correctly (I've checked temp folder that the RipBot uses for output.
I've reinstalled AnyDVD, but I have ripped any Blu-Rays after the installation. I double-checked my Pioneer BDR-205 firmware, and it's up to date.
Any more suggestions?
Thanks,
Mark -
I've seen posts about the current version causing problems. I had a problem and reverted to version1.15.0.if your running 1.15.1,revert to 1.15.0
The current version of BDrebuilder now supports mkv output,you might give that a try instead of Ripbot.
Stalls at 99% complete and then Progress crashes
By upperholme in forum ffmpegX general discussionReplies: 2Last Post: 1st Aug 2008, 13:35 -
playback of HD content sometimes picture stalls ...
By Phat J in forum Software PlayingReplies: 3Last Post: 6th Jun 2008, 13:41 -
Windows XP SP3 and Vista SP1 - Can't wait? you'll have to wait a bit longer
By GideonK in forum ComputerReplies: 28Last Post: 6th May 2008, 16:46 -
DVD Moviefactory 6 Stalls when advancing to 3rd step
By ejai in forum Authoring (DVD)Replies: 0Last Post: 11th Oct 2007, 10:34 -
Nero Express stalls out
By tommyboy9495 in forum Newbie / General discussionsReplies: 1Last Post: 7th Jun 2007, 14:03
