    Apr 2010
    Tolga, Australia.
    Hello
    Do you know of any video software that can enable the below or do you have any that can do this? It would be very useful for many people and save them a lot of time. If you do not know of any, do you know of someone who may be able to write software or modify existing software to do this?
    Currently I am using Media Portal to record TV programs from my duel tuner Hauppauge TV Tuner card. Portal saves the files as TS files. I play them back with VLC Media Player that has advantages over other software I have seen as they can be played back at double speed while understanding the audio. However, I want some software to simply edit the files and trim unwanted parts out. I have not found software to easily do this with TS files and I would rather avoid converting them to another format unless there is an advantage. This is because I have a lot of them to convert and an extra conversion step would be required for each file. Alternatively, a better way would be to use some software other than Media Portal to record the videos that records in another format. Media Portal has some bugs and disadvantages so I would be happy to use some other software if that is better. The TS files take up a fair bit of space on the hard drive. I would rather save files in another format if they take up less space.
    It would be good if there was video editing software that enabled viewing the video so that the screen of the video take up at least two thirds of the computer screen where the window can easily be resized. Some editors restrict you to a very small viewing size. It would be good to have a program like VLC media player but additionally enabled editing while playing the files back at double speed and understanding what is being said. I would like to click a button to start a section of a video to keep or delete and then another button to end the section to keep or delete. This would enable saving parts of the video and deleting unwanted parts.
    It would be good to be able to press a button or keystroke to hop back or forward a minute with one click and two minutes with two clicks etc. Another button or keystroke to go back less than a minute would also be good. This would enable replaying something just seen. I would also like the scroll bar to be easily moved by the click of the mouse to a position anywhere in the middle of the video. As an added bonus it would be good if it could be used like Media Portal to record TV programs. However, this feature would not be as important as I could use some other software to do this
    Currently I have a lot of videos of documentaries and I would like to have them play one after the other in the background while I work without having to manually go to the computer to start playing another one when one of them finishes. Is there software or a method that would easily enable doing this without having to join the files up in one file? If not it would be good to have the video editor easily enable joining files.
    What software do you suggest to do the above or could it be easily created?
    There is a list of free open source video editors at http://en.wikipedia.org/wiki/List_of_video_editing_software . Are any of these likely to be able to do what I want?
    Your help is appreciated
    Regards Richard.
    Apr 2005
    Bremerton, WA USA
    I would give Avidemux a try. It's a little bit obtuse to use, setting the codecs and all but it has been stable for me when I used it unlike some of the others. The price is right, too.
    Apr 2010
    Tolga, Australia.
    Hi
    Thanks for the letter.
    Does Avidemux do all the things that I listed in my question?
    It would be good if we knew someone that has tried a lot of video editing programs including the open source or freeware ones listed at http://en.wikipedia.org/wiki/List_of_video_editing_software
    Have you tried these open source ones or are you able to? How do they compare to the program that you suggested
    If someone tried all or most of them it would enable the programs to be compared and a summary could be written explaining their differences and rating them. Perhaps there are some websites comparing the different programs out there. Please let me know if you can find anything. It would save a lot of people having to download all of them to try them if we could find a comparison or ask someone (that has tried most of them) which program is best for our needs.
    Regards Richard.
  4. Mod Neophyte redwudz's Avatar
    USA
    VLC has a video editor in beta at present that may be very interesting. http://trac.videolan.org/vlmc/ I still use VirtualDub a lot, specifically VD Mod. It's getting a bit old as a program now, but does most of what I want. But I do mostly cut and paste editing, along with filtering and format conversions.
    And welcome to our forums.
  5. Member turk690's Avatar
    Jul 2003
    ON, Canada
    You can also try MPEG-VCR (www.womble.com) to cut and edit *.ts files with. Payware, but cheap & cheerful.
    For the nth time, with the possible exception of certain Intel processors, I don't have/ever owned anything whose name starts with "i".
